Typically when a mobile device is locked, it wants the original e-mail account name and password it was setup with. You shouldn't need internet connectivity to unlock the phone. If you can log into your account at https://mail.google.com/ that's good, but it doesn't guarantee it's the same account the device is using or the original password used.
In some cases, if the device can receive a call, you can access the menu during the call and disable the screen lock.
If you don't remember the username and the account was properly setup at creation time, you can recover the name using "I forgot my username" here: http://support.google.com/mail/bin/answer.py?hl=en&answer=46346 And here's a trick to recover an account name on an Android device: https://productforums.google.com/d/topic/gmail/ydNElvUjJVU/discussion
If you have the username, the following will help with the process to recover the account by resetting the password: http://gmailaccountrecovery.blogspot.com/
BUT... A recovered account or changed password won't have the original password which is what the device needs to be unlocked. In that case the device will probably need to have a factory reset done (read the owner's manual for instructions) and then setup again with an e-mail account (be sure to write the information down this time). If it's setup with the recovered e-mail account, any purchased apps and synced data should be restored. If a new account needs to be created, all previous information will be lost.
An article on this topic: http://einartysen.se/unlock-android-phone-after-too-many-pattern-attempts/
SOURCE: describe how to unlock my
easy as pie download android sdk from google install it on your c drive under android sdk then download and install the usb drivers for your phone then right-click on "my computer" on your pc select properties select environmental variables highlight path select edit and ad in c:\androidsdk/adb/tools then plug in your phone to the pc open a command prompt via the run function on your start window and enter: command then type in "adb" press enter then type in "adb" devices then press enter at this point you can unlock your phone via an adb command listed in the command promps once you type "adb" then press enter ill link a youtube video its not as hard as it sounds its just not the easyest thing to walk a person through with a written discription. if you still dont feel upto it pay someone on craigslist 10 or 20 bucks to do it for you they will offer you the option to root your device witch is awsome but more dangerious or annoying than 90% of android users. sorry for the long explanation. here is your youtube link
SOURCE: i have forgotten the unlock
You can try and call your service provider and they might be able to reset it for you.
SOURCE: hi i have a samsung
The only way to get around this is run the recovery
How to do this
1. Turn off the phone
2. Told down the UP Volume button and power button
3. Wait till the screen comes on and then off
4. A menu shows up and click restore/recover
5. The password is gone.
SOURCE: I can't open my samsung galaxy 5 due to over attempted of different patterns.
Wait for a minute, them retry the pattern.
