Non newtonian fluid - Computers & Internet
  • 3,961 Answers
Non newtonian fluids behave differently to say, water, when they flow. In the case of a Newtonian fluid, the more stress placed on it (pressure) the more strain you see (flow rate), in a linear relationship.
Non-Newtonian fluids are far more common, and the thickness (viscosity) of these increases, or decreases, with increasing stress.
A good example is quality wall paint. It flows on with the brush easily because its viscosity decreases with increasing stress (pressure), but shows little tendency to drip and run (increased viscosity) when on the wall, as stress has decreased to almost nothing.
Posted on Dec 06, 2013
6ya staff
SOURCE:
How do I assemble a national geographic 76/700 EQ newtonian reflector telescope.
Try Googling (National Geographic)(76/700 EQ)(manual) without parens OR contact National Geographic directly with your request.
Jan 30, 2018 | National Geographic Optics
How the specifications of telescopes is read
First you would look at the construction, a reflector or a refractor.
The first has at least 2 mirrors in it, and comes in several sub-types. The cheapest to begin with is a Newtonian, very cost effective. You can recognise these as having the eyepiece at the front end of the tube.
http://www.365astronomy.com/images/10237-skywatcher-quattro-12s-imaging-newtonian-telescope.jpg
Newtonians however have to be optically aligned (collimated) every so often to give a sharp image. This is simple enough when you learn how, but some find it a pain.
Refractors have no mirrors, only lenses, and you can recognise these as having the eyepiece at the rear of a longish tube. They don\'t need regular collimation. The better ones have more lenses in them, and in larger sizes are very expensive.
http://www.astronomyalive.com.au/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/7/0/709eq.jpg
The next spec you see is the aperture, or diameter of the optics. It is the diameter of the main mirror or lens, and governs the light gathering power of the scope. If you live in the city, there is no point to having a huge scope, as it only gathers lots of light pollution. If away from towns, a large scope will pick up faint nebula. 100 - 150mm (4"-6") is a good starter size.
Then you see the focal length (FL) quoted. This is the length of the light path in the scope. In a reflector it is folded up, and can be quite long without having a bulky tube (OTA). In a refractor it is straight, and so is limited in amateur scopes to about 1200mm.
The focal length governs the magnification you see, but only in partnership with the eyepiece (EP). These are interchangeable
http://www.atozastro.com/my_equip/eye_pieces_set.jpg
and each has its own focal length. The magnification is the scope FL divided by the EP FL. So a 1200mm FL scope with a 25mm EP gives a magnification of x48, which does not sound much, but is good for a sweeping view of the Milky Way. EPS range down to 4mm commonly, so there is wide choice.
There is not space here to discuss the mounts, but start with a robust AltAzimuth (AZ), say a Skywatcher AZ4. Another popular mount is the Dobsonian, confined to Newtonian reflectors.
I\'d urge you not to get a cheap department store scope. These are absolute junk with plastic lenses and poor construction. Depending on budget, get an affordable refractor first up, (so you don\'t have to fiddle with it much) with some Plossl type EPs (cost effective) like a
http://www.optcorp.com/celestron-astromaster-90-az-refractor-telescope-21063.html
May 24, 2014 | Measuring Tools & Sensors
Best way (drain and fill or flush)to change tranny fluid and best non-ford fluid to use
Always flush is best. Just draining removes only 15-25% ( depending on transmission ) of your fluid leaving up to 85% old & dirty fluid to contaminate the clean. Flushing forces fresh fluid into all parts until the fluid flows out clean.
Apr 23, 2014 | 2004 Ford Escape XLT
F5 Newtonian Dobsonian 10" I need
Hardin Optical is out of business-- however a well stocked hardware store should carry some springs that will work just fine.
Jul 04, 2011 | Hardin Optical Deep Space Hunter 10...
We've just bought a 6'' Newtonian reflector and
And the brand name and model is???? and what kind of mount does it have?
Need more information.
Mar 10, 2010 | Optics
CELESTRON 127EQ faulty magnification
It won't increase viewing power by hundreds of time but it should be able to show you a close up view of the moon and planets where they look closer (or with the moon, parts of it look closer). When you say it looks further away, something is quite wrong as you know. It sounds like the eye piece is backwards in the mount? Can't imagine what else would make it smaller. Also can't imagine you could even get it in backwards. I have a scope by Meade that is essentially the same Newtonian design. Best of luck.
Dec 31, 2008 | Celestron PowerSeeker 114 EQ Telescope
Need a how to book celestron 114mm newtonian telescope
Here is the manual--
http://www.celestron.com/c2/images/files/downloads/PowerSeeker_114eq_21045.pdf
Dec 25, 2008 | Celestron Optics
Seben 150-1400 telescope
This is a pretty generic Chinese made 6" Newtonian reflector. The one's I have sampled produce excellent images. Celestron has a great online archieve of its manuals. This scope is similar to their C150-HD Newtonian Model #31056. The manual can be found here:
http://downloads.celestron.com/Manuals/telescopes/c150hd_g8n/c150hd_g8n_manual/c150hd_g8n_manual_0802.pdf
Google "beginning astronomy" and you'll get a quartr of million hits. Good over view here.
http://library.thinkquest.org/29033/frames.htm
and here:
http://www.skyandtelescope.com/howto/basics/3304616.html?page=1&c=y
While you are there get a subscription to Sky and Telescope or their other publication aimed at beginners, Night Sky.
Find a local astronomy club and join it.
HTH, George
Jan 22, 2008 | Optics
Computers & Internet Logo
111 people viewed this question
Ekse
Marvin
Marvin
