I currently have two of these scanners that will not scan anything longer than 14". I have another one that works just fine. According to the manual you go into properties on the scanner, click the maintenance tab and then check long doc mode. This doesnt exist on my scanner. Any help would be appreciated.
SOURCE: The scanner pauses half way throught the document
May be the location where it is writing the data is not 'free'. Do a 'deframent' of the drive where you intend saving the data. Ensure there is enough space on the Hard Disk
S. Mohan, Chennai, India
SOURCE: Canon DR 2580C Scanning issue
In Captureperfect, select page size as 'Scanners Maximum'. Select automatic paper size, check the output now. If you select bigger paper size and smaller paper, you will see lack output, outside the paper area.
SOURCE: I have a new DR-5010C scanner. I used to use the
I havent used Canon 2580C and hence cant comment on Scan Panel. But you can download SU5000 or Captureperfect 2.0 from Canon website (http://software.canon-europe.com/). This is easy to use and probably offers more features as compared to ScanPanel. Canon 5010C is a higher model as compared to 2589C and Captureperfect may offer better user interface.
S. Mohan. Chennai, India
SOURCE: Canon DR-7080C Missing page size selection in scan properties
tried this? http://software.canon-europe.com/software/0025523.asp?model=
SOURCE: canon dr-2580c scanner will not save color
Check your file format. If color you can save in JPG format, which is small in size.
S. Mohan
