JVC GR-D770 Camcorder Logo
A
Anonymous Posted on Dec 05, 2013
Driver webcam USB\VID_1B3B&PID_2936 - JVC GR-D770 Camcorder
PnP Device ID: VID = 15D9 PID = 0A41
Device Name: ?USB Input Device
Serial Number: 5&&192F622A&&0&&1
Revision: (Information not returned)
Device Type: Standard USB device -
Chip Vendor: Agilent(???)
Chip Part-Number: A2625
Product Vendor: USB
Product Model: Input Device
Tools on Web: (N/A)
This does not work
Oct 30, 2013 • Cameras
tip
How to Repair a USB Flash Drive
Most people who work with their computer more or less regularly are sure to have a flash drive (and even several of them). Sometimes a flash drive can become faulty, for example after a failed formatting or due to some errors.
Quite often the file system comes to be recognized as RAW, the flash drive cannot be formatted or even accesses... What can be done if that is your problem?
This manual for repairing a flash drive is intended to deal with all sorts of USB drive issues except cases of mechanical damage. The drive manufacturer does not matter, in fact, be it Kingston, Silicon Power, Transced, Data Traveler, A-Data etc. All actions to be taken are given step by step.
Getting to Know Flash Drive Parameters (Manufacturer, Controller model, Memory size)
It may seem very easy to know the flash drive parameters, especially when the manufacturer and memory size are specified on the drive case. The matter is that USB drives, even belonging to one model range and made by one manufacturer can have different controllers. Hence, a simple conclusion - in order to repair a flash drive you need to know exactly the controller model so that you can select the right fixing utility.
To determine the controller model there are special digital and letter values set by parameters of VID and PID.
  • VID - vendor ID (manufacturer identifier);
  • PID - Product ID (product identifier, i.e. identifier of a particular model);
These will be different for various controllers!
If you are not going to waste your USB drive, do not use utilities which are designed for VID/PID other than yours. Very often, a wrongly chosen utility can "kill" your flash drive.
How Do I Find VID and PID?
You can find VID and PID with the help of special utilities, but it can be done without them as well. First of all, go to Device Manager.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-5.jpg
In Device Manager, a flash drive is usually recognized as a USB Flash Disk, so you need to right-click on the device and go to its properties.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-2.jpg
In "Details" tab select "Parent" parameter to see VID/PID. In our case they are as follows: VID: 0204, PID: 6025.
http://www.fixya.comwrite_tip-wyytcj10vubwvpdmj0eoj2yx-1-0.jpg
Choosing The Necessary Utility to Repair The Drive (Low-level Formatting)
Knowing VID and PID we need to find a special utility suitable to restore our flash drive. It is better to use a search engine, Google or Yandex (a sample query: Silicon Power VID 0204 PID 6025).
Before launching such utilities we recommend disconnecting all other flash drives from USB ports (so that the utility cannot format another disk by mistake).
After treatment by such utilities (designed for low-level formatting) a problem-ridden flash drive should work properly again, recognized quickly and correctly by your PC.
Certainly, this repair manual is not the simplest one (you can't do everything by clicking one or two buttons) but it can be applied in many cases to almost all flash drive types manufacturers.
Yet before you start low-level formatting you should understand it means erasing all user information without a chance to restore it. That is, the part of the drive where data is contained will be cleaned completely. Standard Windows formatting does not do that but only applies quick formatting which is basically remarking your drive.
So if you used your flash drive to store some important data before the problems began, and now you need the data to be recovered, it is possible but only before you start low-level formatting. This operation requires special data recovery software. The best choice to suit your needs will be Hetman Partition Recovery.
tip
USB FLASHDISK/ Pen Drive WRITE PROTECT, CAN'T FORMAT, SIZE 0, ERROR SOLUTION
Dear Guys, If you find the problem same as the contents above. Please kindly following this step :
  1. Find VID (Id Vendor) and PID (Id Product) of your type Usb Flashdisk/ Pen Drive, Use This Software USB VIEW, see this picture to find :
2. after you already find your VID and PID, you can enter this website to find correct software to use. http://flashboot.ru/iflash.html , maybe this web use Rusian Languange but no need to worry you just fill up your VID or PID at search Box, see this picture
Good Luck, Or If you need my support, i will do.....
on Mar 22, 2010 • Computers & Internet
MY PEN DRIVE IS DETECTED BUT SHOWING THE OPTION '' PLEASE INSERT DISK IN DRIVE ''
Following this step :
1. you just need to see your ID Product (PID) and ID Vendor (VID), you can use this software to find your PID and VID, USB VIEW, for reference see this picturefd97e60.jpg
after already found the PID and VID, take only for digit behind X.
2. visit this web http://flashboot.ru/iflash.html to find correct software for your flashdisk, just filled up at box like search.
3. or after you know the VID and PID you can contact me to find correct software for your pen drive type.
Good Luck
2helpful
I have a pluscom webcam with mike and i go on msn i can speak and see them and they can see me but i dont have any incoming sound of them i am running windows 7 they have spoken to other people so there...
try this driver for me it's working
Hotfile
Pluscom USB 090514 WCRNS 2936
http://hotfile.com/dl/59502298/9571efd/pluscom_USB_PC_Camera_(50Hz)_090514_wcrns_2936.exe.html
10helpful
3answers
Logitech Webcam M/N: V-UAP9, P/N: 861170-0000, PID: LN54982
I HAVE LOST THE DRIVER FOR MY LOGITECH WEB CAM
M/N: V-UAZ27A
P/N: 861208-0000
SO I AM IN NEED OF A DRIVER
Will not print
check for the installed drivers in the control panel.try uinstalling the drivers and reinstalling them back again...try deleting the registry VID and PID keys if possible(hkey local machine/system/control set 001,2,3,4/enum/USB/VID and PID starting with 7.see if it works.....
I am looking driver for windows xp
first, find the vid and pid infomation of your adapter. insert the adapter to the socket, you a把蓝牙适配插入到USB上,打开设备管理器,选中带黄色感叹号的选项(usb device),右击属性,选中详细信息,在那里可以看到蓝牙适配器的厂商ID和产品ID,VID_后面的数字对应厂商ID,PID_后面对应的的产品ID
171c514eedd08f02b3de05b8.jpg 我买的这个蓝牙适配器,厂商ID为0E5E,产品ID为6622,记录下这两个数值,
C:\windows\inf\ (inf文件夹是隐藏的,得先显示所有文件才看得到),find the file "bth.inf", open it and add a line under the sony.NT.5.1
[Sony.NT.5.1]
USB Bluetooth Device= BthUsb, USB\Vid_XXXX&Pid_XXXX
XXXX is your adapter vid and pid
手动更新驱动,会发现一个名叫my bth的驱动.安装上即可,这样子蓝牙适配器就装上了,用的是windows自带的蓝牙驱动(精简优化过的系统可能没有).自已去试试,感受感受吧
6helpful
2answers
Driver incorrect
Hello, look the device VID & PID in
Control Panel --> System --> System Properties --> Unknown Device --> Details
Es. I Found on my notebook : USB\VID_067A&PID_7561\5&1737F18D&0&2
Then Modify SER2PL.SYS with your VID & PID
Es. :
[ControlFlags]
ExcludeFromSelect = USB\VID_067A&PID_7561
[Pro]
%DeviceDesc% = ComPort, USB\VID_067A&PID_7561
Reinstall the driver
Top JVC Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
