Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft. Front-Loading Washer Logo
Posted on May 11, 2009
CODE DL F what is it!!!! how do you fix this problem. THANKS
We have this Whirlpool GHW9200LQ
we are trying to fix it, and it's giving DL F CODE,
the machine was given to us and they told us, that something was wrong with the door, he fixed that, but we still have the DL F CODE
do you know what it could be!!!!
thanks
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Jun 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
694
Points
It is a 54.00 dollar part that locks the door
2helpful
Our Whirlpool Duet GHW9200LQ washer will not always start a cycle when you press the START button, although it does not give any error code. What's wrong?
you might need a new User Control and Display Board part number is 8181866. the pic below is the User Control and Display Board looks like that
Error code
"dl"indicates a door lock error. A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
Check for the following when dl occurs:
  • Door Lock Mechanism broken.
  • Check Door Lock/Switch Assembly for foreign objects
  • Check Wire Harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you !!
Whirlpool model wtw6600sw9 If stops with code
On this washer, the dl code indicates a failed lid lock mechanism. Pressing pause/cancel should reset the controls.
You may have to unplug the unit for 20-30 minutes, then restore the power.
If that doesn't work, the only other solution would be to replace the door lock assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
2helpful
Machine won't turn on flashes dL F code and gives me short buzzes
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
Replace failed component.
Hope That Helped;
Thanks For Using
FixYa.com
George
Please Rate Me
My husband is trying to fix the washing machine, and we have DL F code, i know is something to do the the door, but he checked the door and I think that is not the problem!!!!We have a Whirlpool GHW9200lQ...
Mine did the same thing. The plastic part that locks the door is bad. My brother repaired mine instead of calling someone the part was 54.00, and it took him 15 minutes to fix. You could be looking at more than that if you call someone out. The front comes off easy.
2answers
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
2helpful
Error code dl then f
sounds like door lock issue but probably not lock itself remove top (3 screws) along back of top ..at rear of machine is control board ..if you are hearing a clicking noise at time door is supposed to be locking try wiggling connectors on control bd if i remember they are the pink wires if door locks then you have a bad connection on control bd may try wedging something under connector to help hold in place but only true fix is a control bd..good luck
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
