SOURCE: Paper tray at front of scanner will not lift.
Disconnect the scanner from the Comp, Try 'page counting'. If the papers go through, then you know feed mechanism is okay. if the tray is not lifting, then you have a problem. Use Qumatool software and check if the tray is lifting. If the scanner tray if lifting then the motor is okay, if not, the lifting motor may need a check.If the motor is okay, but tray not lifting means the sensor in the paper tray is faulty. Check this out.
S. Mohan, Chennai, India
584 065 040 041 582 221 115 071 351 402 034 219 451 371 035
Philips
14PT3685/05 21GR2550/058 21PT532A-05 21PT161B-05 21PT166A/03 MD12E 29PT828C/05 32PW9615/05 28PW6322/05 32BW6332/25 28WVRN 32PW952505 SL6-1 25ST1761 25PT727B/05 21GR2554/05B 28PW6606 21PT161A105 32PW9566/05R TW6328 28MD12E 28PT/4523/25 32PW9525C 28PT4521 24PW6006/05 32TW6517 32PW8515/05 32PF99445/12 42PF9945/12 21PT5505 23PF99445/12
Philips
20PV164/05 20PV230/07 24PW632405R 25PT4475/05 25PT4523/05 28PW6516/05 28PW5324/05 28PW6315 28PW6515 29PT9113-05 29PT828C/25 32PW6322/25 32PW631S 32PW6517 32VW6005 32PW962B 32PW6006/25 32PW6526/05
