I have stock speakers in the front and rear speakers(aftermarkey, but my one rear speaker wire fell off..anyways i hooked up my sub and while im driving if i turn it up to loud with the subs, the deck will shut off, this happend before but it came on 2 days later.. this happend again where i had it up loud and now it won't turn on, checked fuses and wiring..all seem to be good, not sure if theres a reset i have to do or bad connection? for an alpine deck any help is good cheers
SOURCE: alpine cde-9843 . i hand it in and working for 3 days then no sound.
Try a CD lens cleaner[A disk with a little brush and a bottle of fluid. But be prepared for a new player - once the lasers goes its trash can time.
SOURCE: no sound to the in car speakers from my alpine cda-9827 cd player
What kind of car did you install this in? Did it have a factory radio in it? If I had to take a guess I would think that there is a factory amp that you may have hooked the blue wire from the alpine deck to. If this is the case when you switch to CD the alpine deck turns off the power to the power antenna lead(blue wire) and thus your factory amp. If this is the case hook the factory amp turn on to the blue and white wire and you should be good to go.
SOURCE: No sound from subs and rear speakers...
Make sure the Ipod is plugged into the AV input source. Then you may have to go through the menu to select AV1 or AV2 input. This should take care of the problem. Good luck
SOURCE: newly installed alpine resetting
Chevy stock speakers are 8 ohm. You should change out the stock speakers. Or at least dissconnect the back speakers and see if cd player still overloads and shuts off.
SOURCE: on alpine cd3 9852 model,
My setup is the exact opisite here, my cd only turns my amp and subs on, and there's no response with fm mode
