Question about Sewing Machines
I have a CP 6500 Brother sewing machine. It is giving me an E5 code when backstitching ONLY. I can sew forward just fine. Any suggestions??
    New Friend:
  • 89 Answers
Look at your manual. E usually denotes ERROR. The 5 means it is error #5.
Posted on Feb 01, 2014
3 Suggested Answers
bargainbox
Hassy
  • 1388 Answers
SOURCE: machine will not sew forward without backstitching
You have selected the Stretch Stich (SS) mode on the stitch length regulator, just turn the knob around until you have a number 1 - 5 and that should be it.
The model number will be the last digits on the metal compliance plate with voltage etc.....looks like:
V / 1234 / 123454321 / 2016
www.bargainbox.com.au
This then would be a Model 2016
Posted on Nov 28, 2008
Anonymous
SOURCE: Viking 190 sewing machine stuck on backstitch
Found the problem (s) with Viking stuck on backstitch!!!
Two problems:
A: machine is "gummed-up" form old grease.
Solution: degrease machine with a high quality degreaser.. I used a spray electrical degreaser from an automotive store. Turn the machine up-side-down to preform this!
Then relubricate machine. Use a high quality sweing machine lubricant! Also lubricate the inner parts with a qigh quality "Sewing machine" oil.
B: Found that the return spring from foreward to backward was tired.
Soultion: Replace with slightly stronger spring from local hardware store.
If you need pictures, I took very detailed pictures of the reverse mechanism and "return to forward" spring.
Write to AApilot@comcast.net
Posted on Feb 14, 2009
Anonymous
  • 52 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Posted on Jul 14, 2009
Does my Brother SQ9185 sew backwards other than the push button backstitch?
Use the reverse button. That's what it is for. Sew forward and then push the button and sew in reverse.
Machine Darning Jeans Shirt
If you have a darning foot, you can use it (drop the feed dogs) and then you manually move the fabric around while stitching.
Learn How To Mend Clothes with Machine Darning
Oct 01, 2016 | Brother Sewing Machines
Why does upper thread snap when backstitching?
May be an issue with the feed dogs, or possibly a burr on the hook. Lay a peice of scrap material under the foot as if you were going to sew, remove needle, then run machine in reverse to see if it feeds material backwards as it should
Nov 07, 2015 | Singer Advance 7422 Electronic Sewing...
How do I back stitch
You push on the backstitch button. It's the button that looks like an upside down U. If all it does is take a few tiny stitches back then stops...you need to look at the screen...to the upper right you will see the upside down U and a scissors. make sure both of these are not selected. If one or both have a dark background...touch them and the background turns white/clear. Once they are unselected...you can backstitch at the same speed as going forward.
Jun 19, 2014 | Brother SE-270D Computerized Sewing...
Sewing machine not backstitching
could be a computer problem, that needs to be checked
Mar 11, 2014 | Sewing Machines
CS6000-i E5 showed on screen, now my backstitch doesnt work. Is this an adjustment I can make?
The start/stop button was pressed while the foot controller
was connected.
Disconnect the foot controller,
and then press the start/
stop button. Otherwise,
operate the machine by
using the foot controller.
Hope this helps.
Feb 13, 2014 | Brother CS6000i Computerized Sewing...
Looking to tune up brother CP 6500. Squeaking And skipping occasional stitches. What grease to use and where to apply grease?
No grease please, only quality sewing machine oil. Some machines marked the oil positions with red. Small holes. Else take the top and left side covers of and use just a drop of oil where moving parts are joint. Here too you should find small holes that need a drop now and then.
Jan 11, 2014 | Brother CP6500 Sewing Machine
I have a CP 6500 Brother sewing machine. I'm getting an E5 code when trying to backstitch ONLY, sewing forward is fine. Any suggestions?
I have several machines but not a Brother. Have you tried typing in your Model number on the internet and asking the question there? Best wishes, Kate
Dec 05, 2013 | Sewing Machines
I have a Husqvarna Opal 650 machine that was just purchase in July. I am hired to sew headbands, and we use Coats Transparent polyester thread. It's worked perfectly, until last Saturday it suddenly...
change the needle again, the needle could have a burr
check for burrs in the needle plate area and in the bobbin area
is the needle the right one for the fabric being sewed? was the needle inserted correctly into the needle holder?
is the tension correct for the fabric being sewed?
Oct 14, 2013 | Sewing Machines
Two problems:
Jan 16, 2009 | Husqvarna Viking 1
Sewing Machines Logo
61 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
