If it shows 'Video-4' you have to input video signals to its video-4 input terminal. No other terminal will receive any signal. To say more, you can't select its other inputs/TV, without its remote control. No universal remote control will go. Try to get its original number remote control. Contact the authorized service center for Sony to buy a genuine one.
SOURCE: Zenith Concierge hotel tv wont work with my xbox 360
There may be a door in the front of the ste that is locked. You could take off the back and see if there are any circuit boards attached to the front of the ste and then that would show you where the door would be. Sometimes they losck the door with tabs on the inside and has to be pryed off.
SOURCE: unable to turn on video mode without remote. I dont have remote
Who the hell builds a TV w/o a AUX or video button on the TV.... i hate this darn sylvania...
SOURCE: My Sony Trinitron TV does not respond to remote control commands
the tv wont come on the standy timer light is on
SOURCE: sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
SOURCE: TV is turned on-only see blue screen that says Video
if only see blue screen indicate no video signal, check the yellow cable.
If ur ps3
console wont start up....then the things to check are>>> 1.check ur
power cable 2.check whether u have inserted the disc properly and precisely.
3.check the insertion of memory card... 4.check the video port.......
still the same problem,don worry check out the
following Repair Guide..... CLICK
HERE
