If the monitor gets no signal it will show orange. or ,It's hibernating or sleeping. Shut down computer, reboot, open Control Panel, Power settings, change to High Performance, change Hibernate to never or disable, change sleep to never or disable. Shut down the computer and monitor when not in use. It will last longer and reset the computer every day when turned on.
Go into the setup menus, and look for an option that is standby timer, or auto power off. You should then be able to disable the feature, or change the time duration.
This is assuming that you are not using the "sleep" function.
hmmm is it your monitor going to sleep..or the machine? might the computer still be running?
if it's the computer go to power setting and change to your pref
hi i locked my sim card, i went onto 02 website and went onto PUK code. it asks you to put your phone number in then comes up with the code. i put the code in and it it worked
Dude, I had the same problem, the screen everything works fine when I use the TV out,
Check it out and tell me. I already call Sony and they will replace it with a new one, I recommend you call them if you still your warranty and your receipt.
or'
If the LCD screen suddenly turns dark
Check the Backlight Auto-Off setting If the Backlight Auto-Off setting is turned ON, the backlight will turn off after a set period of time. Press any button to turn the screen back on. To check the Backlight Auto-Off setting:
From the XMB™ menu, go to (Settings) > [Power Settings] and press the button.
Highlight [Backlight Auto-Off] and press the button.
Select a time interval and press the button to save. Select OFF if you wish to disable this feature.
Check the Auto Sleep setting If the Auto Sleep setting is turned ON, the screen will turn dark after a set period of time. Press any button to turn the screen back on. To check the Auto Sleep setting:
Highlight [Auto Sleep] and press the button.
Check the Display Button Check the Display button on the front of the PSP system. Pressing the Display button (located to the right of the PSP logo on the bottom front) will cycle through the brightness settings of the LCD screen. The brightness setting can only be used when the PSP system is plugged into an electrical outlet with an AC adaptor.
