Question about Dell Latitude C640 Notebook
System disabled 03482 on dell vostro 1000 - Dell Latitude C640 Notebook
6ya staff
SOURCE:
Anonymous
  • 108 Answers
SOURCE: Dell Vostro 1000 won't turn on/no power at all
The power connector within the laptop maybe broken. Not sure about Dell's but many laptops have only solder points holding the internal power connector to the motherboard. With too much agitation, the internal power connector becomes loose and then broken.
More info will help, does a light show on the laptop when it is plugged in? Have you tried removing the battery and lettting the laptop sit for about 10 mins, without any power? Have you re-seated the ram?
These are all possibilities of the symptom you have.
Let me know and G'luck!
Posted on Oct 27, 2008
Anonymous
  • 413 Answers
SOURCE: Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
Hopefully you can find something helpful on this site. Basically you need to flash or reset your bios now. this site also has some links to remove upgrades. LIke i said i hope this helps.
http://www.user-guides.co.uk/Dell/DellManuals/Dell.asp?keywords=Dell+Vostro+Manual&recor=1
Posted on Dec 29, 2008
Anonymous
  • 66 Answers
SOURCE: Dell Vostro 1500
There is a solution on these Dell Models.
Go to Start>RUN and type in MS Config
Go to the startup tab and uncheck the PCMServices.exe
Restart the computer, and it should fix it.
Paul
Posted on Mar 06, 2009
Anonymous
  • 35 Answers
SOURCE: How do you turn off numlock on dell laptop
try using the on screen keyboard which is available at Start -- All Programs-- Accesories-- Accessibilty -- Onscreen Keyboard..once u r there u can click off the num key from the onscreen keyboard.
Posted on Jun 20, 2009
Anonymous
  • 244 Answers
SOURCE: My dell vostro 1000 won't turn on the green light
Try to do this: (Draining flea power)
1. Unplug the ac adapter (if connected)
2. Remove the battery
3. Press and hold the power button for at least 10sec.
4. Put back the battery and ac adapter
5. Turn it on
- check if you can now boot to windows, if not there could be a hardware problem and next step would be running some diagnostic test on the computer for hardware problem.
Posted on Dec 09, 2009
How do i restore to factory settings my Dell Vostro 1000
Try here...(http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=gen&docid=DSN_336966&isLegacy=true#Issue3).........or here........(http://www.techsupportforum.com/forums/f108/solved-dell-vostro-1000-restore-from-recovery-partition-issue-445057.html)
Nov 20, 2011 | Dell Vostro 1000 Laptop
How can I fixed a defective motherboard of my dell vostro 1000 laptop? where can I order the exact type of my vostro 1000 motherboard laptop?
Only Dell will be able to supply a replacement Dell motherboard.
Telephone Dell, and ask for Technical Support, to find the part-number and the (HIGH!) cost.
Jul 18, 2011 | Dell Vostro 1000 Notebook
After a recovery cd reinstallation the wireless network adaptor does not show in device manager or system information.Dell Vostro 1000
You have to instal the driver for wifi adapter separately from the CD that came with the box, if u dont have the CD, visit the official website of dell and download and install the driver, follow the link;
http://www.laptops-drivers.com/dell-laptop/vostro-1000-dell-support-center.html
Hope this will solve the problem
Sep 20, 2009 | Computers & Internet
The battery is not identified the system will not charge battery
I had the same problem with my 2 years old vostro 1000. I updated the bios and problem solved.
Sep 03, 2009 | Dell Vostro 1000 Notebook
Where is the BIOS Password Clear/Reset jumper located in a Dell Vistro 1000?
There is no Jumper on a Dell Vostro 1000 to clear the password. You will have to contact Dell Technical Support, Complete a ownership validation to confirm you are an authorized user of the system, then they can provide you with a Master Password to clear the password
800-624-9896 in USA
Jul 10, 2009 | Dell Vostro 1500 Notebook
Wlan not working on dell vostro 1000
Try disable, then re-enable the driver, if still no luck, try to locate the wireless adapters properties an check to see if all is in order, ch, SSID, everything must match to the wireless signal. (by the way where is the signal coming from ?) your router ? or else where ?
bigJDL
Apr 15, 2009 | Dell Vostro 1000 Notebook
Dell Latitude C640 Notebook Logo
143 people viewed this question
Ekse
Clive
Clive
Alun Cox
