Question about Watches
Relic digital watch
Need instructions for setting time.
  • 5 more comments
  • shadow_92111 Nov 14, 2007
    Trying to reset time to meet time change...
  • Anonymous Nov 19, 2007
    can not change time
  • sun_rose Dec 14, 2007
    It seems to be hit or miss. I did manage to set the time, and then just now, by pressing mode and st/stop at the same time, changed the time of the alarm (which woke me precipitously earlier!) by hitting the lap/rset button when the numbers started flashing. That had happened earlier with the time. The watch appears to have a choice between 12 hr and 24 hr time, an alarm/hourly beep, and a stop watch. The alarm doesn't always show up with the mode button, ditto changing the 12/24. The watch had no instructions. It reads ACQUA 1100 set stopwatch on the front. And for some reason there are two indiglo buttons that seem to serve no other function (i.e. changing the time/alarm). Seems odd to have two: one is upper left, the other, bottom middle.
    I'd love some consistent instructions too!
  • conleysusan Dec 19, 2007
    need instructions for setting watch. thanks sue conley
  • Cali-Kate Mar 09, 2008
    Has anyone figured out how to set the time on this thing?
    Thank you,
    very frustrated consumer
  • Anonymous Apr 03, 2008
    We can't change the time either. Help please.
  • Anonymous Apr 29, 2008
    Hiya. I have the same problem. I've tried contacting Timex, to no avail. The watch came with no instructions and while I can set the alarm, I can not seem to change the time. Has anyone had any luck with sorting this out?
    New Friend:
Hold down the reset button until the hour digit starts to flash then to change the hour press the start/stop button then to change the minute press the mode button and keep pressing start/stop button until you get to your desired minute and just continue those steps through the date.
Posted on Mar 11, 2011
I'm not sure if my Relic is the same make of yours, but it is digital. All you need to do is hit SET which, if you're looking at the watch straight on, is the top-left corner. The seconds should start blinking. Now you hit MODE (bottom-letft) to cycle through the hour, minute, date, day, (or even if you would like it to display in the 12 hour AM and PM setting or 24 hour military time), and use ADJ (top-right) to cycle the digits upward or to reset the amount of seconds to 00.
Posted on Jul 21, 2008
We still haven't figured out how to fix the watch my daughter got for Christmas. Has anyone found any better directions?
Posted on Apr 04, 2008
Hmmm
Posted on Mar 19, 2008
4 Suggested Answers
6ya staff
SOURCE:
escapement
Arturs Kalnins
  • 2338 Answers
SOURCE: set the date on my new relic watch
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all RELIC watch manuals.Rate me, please
Posted on Mar 23, 2010
Gary Randall
SOURCE: setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
Go to the home site of the particular brand of watch you own. They should have the instructions for just about every watch configuration they manufacture.
Posted on Sep 28, 2010
jaystwin
SOURCE: how to set the time on relic watches
Not a bad design actually... just poor support since the instructions aren't even available on relic's website.
To set the time on the relic zr85048:
On the back of the watch, you will see a small cutaway or recess at the base of the crown. Insert a thumb nail, or some thin object under the crown and pull upward gently. Rotate the crown in the raised position to set the time. When finished, push the crown down. Done.
Posted on Dec 18, 2010
How to set the time and day and date on a relic zr15701
Pull the crown out once to set the date. Pull it out a second time to change the time. Of course move the crown up or down and see if it will change.
Dec 24, 2013 | Relic Degrade Pocket Watch
Tip
RELIC is made by FOSSIL, so the watch manuals are the same as for FOSSIL watches. Find them here: http://www.fossil.co.uk/webapp/wcs/stores/servlet/ContentView?langId=10&storeId=32553&catalogId=20002&page=instructions
on Jan 25, 2010 | Watches
How do you set the time on a Relic ZR85049 pocket watch?
the crown in the top of 12 o'clock must be pulled. and turn it to adjust the time.
Jul 23, 2011 | Relic ZR85049 Pocket Watch for Men
Need to know how to set the time on my watch
Mar 27, 2010 | Watches
Set the date on my new Relic watch
Mar 22, 2010 | Relic watch
Does not run. does this watch have a battery in it?
There are two types power sources for watches. Automatic and battery.
Automatic needs to be either wound by the crown (winder on the side) or wound by the movement of the wrist while it is worn.
The battery powered is self explanatory.
Since you didn't include the model it's difficult to say for sure because Relic makes both automatics and battery powered watches. Although I can tell you is most automatics will clearly labeled. If your watch say automatic somewhere on the face or back you need to contact Relic for service because your watch has a 12 year warranty.
To prevent violating your warranty a jeweler should be the one who replaces the battery if it is battery power.
I included the link to Relic watches below for info on the warranty and instructions.
Hope this helps.
http://relicbrand.com/
Nov 13, 2009 | Relic Multifunction Watch
How to set the time on relic watches
I had to go to the Sears counter to fix mine. The sales person had to use TWEEZERS to pull the serrated knob up. He had to really work at it. Once it is pulled up you can twist the knob to set the time and then push the knob back down. What a stupid design.
Dec 27, 2008 | Relic Degrade Pocket Watch
Setting instruction on a Relic New Relic Wet Mens Chronograph Black Watch ZR15458
Sep 03, 2008 | Watches
Relic Watch Battery
http://www.apexbattery.com/relic-watch-battery-watch-batteries-relic-watch-batteries.html ... I've had 2 different sources take me to this same battery, although the Relic model I'm using is a ZR11586. "This battery is for ALL Relics," is what they keep saying.
Apr 22, 2008 | Watches
Watches Logo
2,179 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
