Tablets & eReaders Logo
Lyle Sikes Jr. Posted on Dec 05, 2013
How do i disable the text in the upper right of the screen
How can I get my tablet out of the split screen mode and/or disable splitscreen
To disable the split screen go to the Home screen and tap on Apps. Tap Settings. Tap on Multi Window. Tap the Multi Window Switch ( located in the upper right) to enable it disable.
How do i turn off the text to speech feature? It has been accidentally turn ed on 3 times. can't get to settings to turn off.
Step 1
Swipe the Status bar at the top of the screen towards the bottom of the screen to display the Quick Settings menu, and then tap "More." To open the Quick Settings menu in Explore by Touch mode, use two fingers to swipe down the Status bar.
Step 2
Tap "Accessibility" to view all settings related to accessibility. Locate the Text-to-Speech and Voice Guide options in the menu.
Step 3
Turn off the "Text-to-Speech" and "Voice Guide" options to disable the voice capabilities of your Kindle Fire HD.
1helpful
2answers
Screen keeps rotating while I am trying to read?
It should not rotate if the position is locked. To lock the screen, pull down the upper menu by either touching the screen on the upper right or (if it's an HDX) sweeping down from the top. On the left is an icon, the lock screen icon. Tap it until it reads "locked". If this does not work there may be a malfunction which requires a repair.
How to clear auto field on ipad?
Go to Settings, then Safari, select Passwords & Autofill, select Saved Passwords, tap Edit in the upper right corner, then check the box next to both https://www.facebook.com and https://m.facebook.com, then tap Delete in the upper left corner. This will disable automatic fill-in of the username/password fields when logging in to Facebook using Safari.
2helpful
5answers
How to disable voice prompts on ipad ?
Settings > General > Accessibility > Voice Over > Off
This is in the Vision section and is intended to assist the visually impaired.
How do I enlarge my text size on my Kendal Fire tablet
Assuming you are talking about Amazon's Kindle Fire:
Go to the main screen, pull down from the top, in the upper right hand side there is settings, then go to Accessibility, about half way down there is a switch for "Use Large Font Size". That increases the size throughout the whole system.
Or if you are asking about while you are reading an eBook? While in the eBook click the screen to bring out the settings menu, There is a button that says: "Aa - View" Click that, then you can click the Aa with an arrow above it and it will increase the text size for your book (You can also choose a different font which may be easier for you to read too)
Turn off predictive text hudl
Go into system to Language and input.
Click on the UNTICKED Google Keyboard English-box at right of page.
If its like my mark 1 Hudl or my wifes Hudl it then shows a Language screen.
Go back and double click the above and go down to text correction where you can either switch off or adjust the sensitivity of the predictions.
Once you have done this a single screen click shows you this "missing"screen.
If you totally dislike the Google keyboard then go into language screen and choose Qwerty keyboard.
2answers
Problem with the touch screen an stylus
Press the Up + Down buttons at the same time. This will turn off the "Digitizer" function on the tablet and allow the user to use their finger, the stylus, or blunt end of a pen.
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
