Question edited for clarity. So few words, so many mistakes. It looks like the year is wrong for a Prowler XT and Error Codes have 4 digits not 3.
Question moved to model category.
See if there is a button you can press along the F1, F2 buttons, you may have to press and hold the FN key and one of these buttons to re-enable the touch screen
code p 0420 refers to cat converter system bank 1-efficiency below threshold ====causes --cat converter---wiring ---Heated oxygen sensor (HO2S) in the manifold before the cat converter
as the cat converter is new , that will not be an option as for the rest if the codes were not prior to the cat replacement , I would suspect wire harness problems from the cat fitment
possible to use a scan tool to reset the ECm
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
F2 with sub code 33 - grid voltage wrong, either too high or too low;
F2 with sub code 35 - grid voltage correction will not work during simulation;
F2 with sub code 37 - drum mark sensor adjustment required.
You may post further comments for more help or information......
the drivers are available on jvc.com's archives. The installation manual is also available there. I downloaded them 03/08/2008. The key to the installation is to run thru it 4 times. That's right, the manual tells you that this will happen. Without the manual i thought something was wrong when it seemed to roll back to the 'New hardware detected' message. Stick with it and run thru it and after the 4th time ImageMaker will see the camera.
