Question about Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
USB write protected - Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive
Cannot format usb says write protected but there is no write protection for the usb
Reinhard, Check the attached links,instruction and guides on removing USB write protection, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
2 ways to fix write protected USB drive or SD card
How To Fix Write Protection Errors On USB Stick
How To Disable Write Protection from USB Key
How to remove write protection on generic usb disk drive
Jun 16, 2016 | Electronics - Others
Write protection
Write protection means you can view the information stored in it but you can't write and transfer the information to it.
For removing the write protection follow the below mentioned steps:
1. Right click on the USB stick
2. Go to properties and uncheck the read only or write only protection option.
May 12, 2013 | EDGE Tech Corp Edge Diskgo Mini - Usb...
My transcend pendrive is changed by write protected, how to remove the write protection?
You can format it, and encrypt usb drive with password with usb security software. such as http://kakasoft.com/usb-security/how-to-password-protect-usb-on-windows.html
Mar 27, 2013 | Electronics - Others
How to remove usb write protection
Turn on your computer and plug in the drive after your operating system has loaded.
  • 2
    Open "My Computer" and search the list of drives until you find your USB drive letter.
  • 3
    Right-click on the name and click "Properties." Once the options have loaded, go through the tabs until you see the option to remove write protection. If this does not work, go to the next step.
  • 4
    Visit the company website for your USB drive. Go to the help or support section and search for "write protection."
  • 5
    Click on the download section and search for "write protection software remover." Download the program and install it on your computer.
  • 6
    Open the software program. Go to "Option" and click "Remove Write Protection" to unlock your USB drive.
  • Read more: How to Remove Write Protection From a USB Drive ' eHow.com http://www.ehow.com/how_4924168_remove-write-protection-usb-drive.html#ixzz1BY4ve3fh
    Jan 20, 2011 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
    Verbatim tuff n tiny 4gb usb drive is write protected but has no slider. How do I unwrite protect it?
    It has password protection. Open My Computer on your PC, insert the USB drive, open the password file, enter your password, then select the option to remove password protection from the USB drive. If this does not work, contact Verbatim for a solution, these USB flash drives have lifetime warranties.
    Dec 12, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
    My verbatim USB 2 GB is write protected. I am not able to remove write protection. Please suggest to solve the problem.
    Nov 12, 2010 | Verbatim CORPORATION 94933 USB 2.1GB...
    How to reformat a write protected usb?
    No need to reformat your write protected USB. The hings you should do is to slide to small button you can see in your USB to remove the write protected.
    Mar 29, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
    Write protected 4 GB GENX USB
    I ve a 4 GB genx USB that.It become write protected. How do I remove the write protect so i can reformat it? The device doe't have a write protection switch. What's wrong with it?
    Jan 16, 2010 | Electronics - Others
    Usb not formating due to write protect
    Some usb pen drives,  if thats what you mean? They have a little button on the side of them to protect the contents of the usb pen drive. Check that, tyhen go to "My Computer" look for pen drive, Right click and format.
     Best of luck.....
    Jul 24, 2009 | Electronics - Others
    My usb drive is write protected i cant format it pls help....
    Have you tried doing it from another PC? If the same problem persists, look closely at your drive and check for a tiny switch that has a lock label on it- it maybe switched to the lock position. Most USB drives has this switch for write protection.
    Jun 24, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
    Verbatim CORPORATION 94933 USB 2.1GB Store-n-go HD Drive (VE94933) Hard Drive Logo
    32 people viewed this question
    Top Verbatim Computers & Internet Experts
    ChinthakaJ
    ChinthakaJ
    Duke Bells
    jdthefixer
    Are you a Verbatim Computer and Internet Expert? Answer questions, earn points and help others
