SOURCE: hl-dt-st dvd-ram gsa-h55n LG DVD drive not reading DVDs recently
Hl-dt-st dvd-ram gsa-h55n LG DVD drive not reading
It would appear that the problem you are experiencing could be due to 1 of the 2 following items;
1. Re-install the software driver & software that came with the drive.
2. Set the region /Country that the drive will be working in or the language that you understand (USA=Region 1). It should be noted here that this option has a limitation of being changed up to 5 times but once it hits the fifth time the drive will be permanently set to that region and can not be changed anymore for the rest of the drives lifetime!!! The drive will usually work fine once it has been set (the default from the factory is ZERO (NOT SET)) and that may work fine for a while but it should be set to a region and it will understand all previously burnt /movie dvds that have this option set in the data already.
Good Luck!
Rich Lilja
SOURCE: HL-DT-ST- DVD-RAM GSA-H22N
I Have A : HL-DT-ST- DVD-RAM GSA-H22N DVD Burner That Works Fine With (CD Burning/ Reading) & (Data Burning/ Reading) But I Have A Very WIERD Problem With The DVD : Here I Go, When I Use Any Program To Burn DVD Like Nero, DVD Shrink Etc.. (It Appears That) The Movie Is Burning Well, Because In The Burning Process It Doesn't Says Something Like:Bad Disc, Not Succefully Burned Or Any Sign That The DVD Burner Is Damaged , Also When It Finish Recording You Can See The Data Burned In The Disc By The Lines It Forms BUT !! I Don't Know WHY The Fu$%@@ , When You Test The Movie In Any DVD Player , Comp OR Whatever THE MOVIE DOESN'T WORK.
SOURCE: hl-dt-st dvdram gsa-t40n ata device driver curupted
Problem occurs when vista registry entry is corrupted. The steps to resolve this are as follows:
This solution fixed my problem.
SOURCE: HL-DT-ST DVD-RAM GSA-H55N cannot detect dvd disc
I have same DVD writer and I am facing the same problem. During R&D for such failure on google I came to know there are two different Laser Diodes for CD and DVD. CD read write is working for me. I think DVD r-w laser has some problems. I am currently looking for options to get the new laser diode. As soon I replace the diode and see my DVD writer working. I will upload the video to replace the diode for you all.
Click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard
hope this helps
