How to repair tension
SOURCE: euro-pro sewing machine repair
If you call the company, they will probably send you whatever you need. 1-800-361-4639
SOURCE: i need to find a replacement power cord / floor
Is it possible for you to take a digital picture of the spot on the machine that the cord plugs into and email it to me?
Sewing Machine Foot Pedals
SOURCE: help me find a manual for a euro pro 7133 sewing machine
I hope this helps. It took some searching but this is what i found. Good luck!
http://www.sharkclean.com/manual/7133_REV_1204_ENG-SP-FR.pdf
SOURCE: I have a EURO -PRO
Hi janna
have you tried adjusting the top tension first?
if you have a drop in bobbin then it has to be adjusted at a sewing shop
the bobbin case you take out of the machine you can, using a small screw driver,,here's how
lower bobbin tension--
to test the bobbin tension,
remove the bobbin case & bobbin,,
hold it by suspending it by the thread,,
**** it once or twice,,
if the tension is correct, the thread will unwind by about an inch or two
if the tension is too tight, it does not unwind at all
if the tension is too loose, it will drop too much
to adjust turn small screw on the side of the bobbin
to the left is tighten
to the right is loosen
Click the link on the right-hand side of the page below the text box, which reads "Customer Service: Click Here." This will direct you to a contact page.
