This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Delete Inbox Messages Blind Nokia Broken ScreenPress Central Navigation Button to get Menu
Press left once
Press up once - Message Menu
Press Central Nav Button
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Press Button above call end several times to exit from the menu
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken ScreenPress Central Navigation Button to get Menu
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
