Model #mcd990arb
SOURCE: Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
SOURCE: Microwave keeps shutting off
The magnetron is overheating, tripping the thermostat, which shuts off all power until it cools down.
This is usually caused by a blocked air vent, failed internal cooling fan, or failing magnetron.
If it's out of warranty, I'm sure you'll find it's uneconomical to repair, even if you could get parts for this brand.
Good luck.
SOURCE: My Panasonic NN-L530BF Microwave Oven comes on for
Hi this ONLY ever happens when you have had a catastrophic failure inside the MW, usually the power supply and or the magnetron. Most often they are NOT an economic fix and replacement is the cheapest and best option, should you still wish to try to repair take it to a professional repairer and only first ask for a "Quote" and go from there.
SOURCE: TURNTABLE AND LIGHT NOT WORKING
Just fixed one with same problem. Replace small relay on pcb and you are good to go.
