Home Security Logo
Posted on May 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Changing code on home alarm system
How do I change the code for setting the alarm? I had a break-in recently and woudl like to change the code. It is the alarm system for a home, and I cannot find my user's manual. I have the current code.
  • 1 more comment
  • securetim May 11, 2010
    need to know what type of system it is.
  • Anonymous May 11, 2010
    Do you know what model of GE panel you have. It should say on the panel box.
  • Donna Husselbee Jul 12, 2018
    Eurosec pr 5208
Anonymous
Level 2:
New Friend:
  • Expert 36 Answers
  • Posted on Nov 29, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
36
Questions
Helped
42145
Points
136
Important. What model is your alarm system
1helpful
Hi everyone, I just recently bought my home & the previous owner did not leave any manuals/guides. My alarm is Honeywell 6165EX and it keeps beeping due to low battery.
Question edited for typos.
Question moved to Alarms.
In my experience there is a small lead acid battery and this confirms it from here
https://www.manualowl.com/m/Honeywell/6165EX/Manual/463468
Built-in charger for sealed lead acid or gel type batteries.
They are easy to change, they just have a couple of pull off spade connectors. The reason for the battery is so that cutting the power to the house doesn't kill the alarm.
The number you gave is only for the keypad.
https://www.google.com/search?q=honeywell+6165ex
There should be a control box and inside it you will find the battery. It is small like a motorcycle battery but thinner. A bit like this
https://www.amazon.ca/Alarm-Home-Security-System-Battery/dp/B007GCDOV2
https://www.google.com/search?q=honeywell+house+alarm+battery+replacement
1helpful
MY ALARM SYSTEM KEEP BEEPING UNCONTROLABLY..ADEMCO ALARM
Resetting Your Installer Code
1. The installer code (IC) is the code that allows you to access the system programming. If you forget your IC, your alarm company probably won't give it to you. This is because they use the same IC for many installed units and keep it a heavy guarded secret. If your forget your IC code, you're going to have to reset it.
First locate and disconnect the transformer. This is a cube-shaped wall outlet, usually placed around the alarm control panel. Next, shut down the alarm system's power supply. You may have to unplug a battery if you have a secondary power source connected to the alarm system. Once the alarm is powered down, you will reconnect the transformer and the battery in that order.
The rest of resetting comes on the keypad. Within 30 seconds of powering up the alarm, go to your alarm key pad press down the * and # keys simultaneously until you see "20" displayed. At the same time, you should see "Installer Code." Enter your new installer code while the "20" is still on the screen. Your installer code will be four digits. The keypad will beep to acknowledge the new installer code. After the keypad beeps, press *99 to exit the program. To check if you have reset the code successfully, enter your new installer code and press 1 (off). The keypad will beep once if you have successfully changed your installer code. If it doesn't beep, repeat the process.
Resetting Your Master Code
2. The master code is usually only used by the home owner. Other users codes can also be set up, including manager, babysitter, gardener and housekeeper codes. The home owner will use the master code to set up these other codes. The master code is also the code you will use when you come home and need to deactivate the alarm before it goes off.
To reset your master code, type in your installer code, press 8, press 02 and then punch in your new master code. Press 1 to turn off the programming. Your keypad will beep when you successfully reset your master code. You can now activate and deactivate your alarm system as you please.
Read more: Ademco Alarm Resetting Instructions ' eHow.com http://www.ehow.com/way_5752912_ademco-alarm-resetting-instructions.html#ixzz3pC2j96jl
Changing the alarm code on the gaurdtec 500 series alarm
For a guardtec 593
Programming User Codes
(Master code only)
system.
1) With the display showing ' Un ' enter a Master code
2) The display will show ' SE '
3) Press NO five times, the display will show ' Uc ' (flashing).
4) Press YES, the display will show ' U- '
5) Enter the User number you wish to program (1 to 7) followed by YES
6) The display will show ' Co ' Enter the required code (4, 5 or 6 digits) followed
by YES. (Entering 000000 will delete an existing code).
7) The display will show ' t- ' enter the code type from the following list
1 = Set Only 2 = Main User 3 = User 4 = Master followed
by YES. A full description of code types is given on page 3.
8) The display will show ' Uc ' (flashing)
If you wish to program other User codes return to step 4
Or
To return to the Unset condition press 0
this is for the led version.
1helpful
I have a 1997 Toyota Camry. Recently, the security alarm malfunctioned, blaring the alarm and the remote control on the keys wont deactivate the system even after changing the batteries on them. I recently...
You need to reset the alarm by inserting the reset key(small plastic devise with visible contactors that should be with the keys) for a few seconds in the it's hole in the right-hand rear speaker. Open the boot look at the underside of the rear right-hand speaker to locate the hole.
Dont know the reset code or anything about home security alarm sy
need to know brand name of system. IE Ademco, bosch, DS, it will be on the inside of the alarm panel.
2helpful
2answers
Paragon alarm code
I have recently moved into a new property and it has a paragon plus alarm system fitted. I have tried contacting the previous owners for the alarm code, but to no avail.
Does anyone know a way around this problem?
2answers
Optima house alarm
after a power cut alarm goes back to factory setting 0123. you need to use this code to re program alarm
Buzz when changing cycles
there isnt, or at least shouldn't be a buzzer to let you know its changing cycles, only end of cycle. if its buzzing betwwen cylces theres problem a woudl assume eith timer( if theres a selector forit try turning of end of signal chime any way
Top Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Home Security Expert? Answer questions, earn points and help others
