Mitsubishi WD-62825 has vertical hold issues with certain TV commercials, especially all white screens. It also has a small portion of the upper part of the screen that shifts horizontally to the right. And overall, the picture is dark. However, all issues disappear when I change channel to my cable providers HD channels. Any ideas?
SOURCE: Philips Magnovox Rear Proj. TV wont keep vertical/horizontal hold
Hello clifftonian,
I would suggest checking the HV trippler block and the voltage output from the IHVT (Integrated High Voltage Transformer), and comparing them against the schematic diagram. In addition to this after solving your HV problem I would suggest doing a complete convergence adjustment, both static and dynamic. Just don't go replacing parts because that approach does more harm then good. Troubleshoot the problem and find out what other parts are marginal and replace them all. Your stepdad is correct with a good place to start.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
SOURCE: connecting hd cable box to philips 60 rear projection
So, You have Five cable leads, The rgb get plugged into there corresponding colors and the other two are your Red and White Audio Input ------Correct? You do not use the in4, that is for a pc with horiz and vert sync. You use input 1 rgb and plug the red and white into the audio input.....your done!
SOURCE: Picture shrinks toward the center of the screen
Common problem with Philips sets.
If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original chips, email/phone support, etc.
SOURCE: Philips HD tv has no picture
common fault this , normally the fuse has failed on y-main board due to shorted thick film unit
unfortunately its not a cheep repair job.
SOURCE: My Philips Magnavox 50 inch projection tv picture
my philips projection tv model number 50pl9126d/37 has a dark screen
