Vacuum shut off in the middle of use. I removed hose and removed debris the was clogging hose. Does the motor need to cool before it will turn on again
SOURCE: debris getting stuck in vacuum hose
Check that the filters are completely clean. If there are clogged they would have to be washed and then dried to room temp (or a low temp tumble dryer, put the filters into a pillow case with a towel and install into the machine) Tip the bissell backwards to make sure the bottom bin is pushed and locked all the way in. Only when the two seals meet will you know that the bin has locked in properly. Unhook by prising the main hose at the back off to check for clogs as well as the main hose at the bottom and the main dust channel at the sole plate where the roller bar is. You may have to remove the bottom plate to check for any obstructions behind the brush bar.
I have the Easy vac myself. Its not an Easy machine to maintain when it gets clogged!
SOURCE: Need to clean hose.
I filled a bowl with hot bleach water and sucked the water up. It cleaned the hose pretty well (along with the gunk that was stuck in the hand wand). Mine was filthy. It looked like it had mold growing in it. Then I ran several rounds of hot water through the hose. I alternated hot water & bleach. Did this about 8 times. It is not perfect, but it sure does look a lot better. 90% of the gunk is gone.
SOURCE: Re: model 3522-5 Bissell proforce bagged vacuum hoses clogged
Worked perfectly. Thanks, jade_greeney. We thought we were going to have to shell out $100+ for a new vacuum.
SOURCE: Clog and possible overheated
Hi Jen,
It sounds like your vacuum overheated due to the clog. This is a protection feature most vacuum cleaners have to prevent the vacuums motor from burning out due to a lack of air flow. The safety switch will activate and shut the machine off for a short period of time until the motor has cooled.
You should remove the clog from the vacuum, and make sure that your filters are clean. This model has a hidden filter directly underneath of the bagless dirt cup in a black tray that says "PULL". Pull this tray out, inspect the filter, and if dirty rinse under water until clean. Make sure that the filter is completely dry before reinstalling and using the vacuum cleaner again.
After inspecting all of the filters and removing the clog, let the vacuum cool down (usually just a few hours) and try to turn it on again. When you turn it on, remove the attachment hose and make sure that you have suction from the hose. When putting the attachment hose back down into the floor section of the vacuum, listen to see if you hear a change in the noise the motor makes. If you hear a higher pitched squeeling noise, this indicates that there may be a clog in the lower section of the vacuum as well. If the noise is the same then you should be ok.
If the vacuum continues to shut itself off, then either the clog has not been completely removed, or the safety thermal switch inside may now be faulty, and only at this point should you take your machine into a repair store.
I hope that this helped you!
Chris Jones
GoVacuum.com
SOURCE: the vacuum i've had for 6 months has very liittle
as this unit has 3 filters on it, a lot of people forget about the one filter that will cause all of your trouble here.
There is the exhaust hepa filter, no problem, your unit is pretty new, it shouldn't be a problem.
There is the circular filter in the chamber where all your dust and debris collects. It is in the top portion and will come out with a twist. This filter is washable. Warm water and no soap.
The third filter, and this is the one that is most commonly overlooked, is just below the dirt container you can take out and clean. It is in a grey "tray" that pulls out and the sponge filter is in the tray. As a word of warning, it is probably pretty dirty. Again just wash it, warm water no soap, and you should be good to go.
PLEASE make sure that the filters are DRY before putting them back into your machine.
Good luck.
