Wd 320gb portable hard drive not seen in safely remove icon
well i cannot actually figure out your problem well all windowsxp and windows vista allows you to safely remove your usb device well wats the error like diid you check microsoft for lates updates and patches !!try it oderwise tell me the exact error or problem!!thanx
SOURCE: Hooking up the WD Passport to a USB enabled CD/DVD player possible?
The WD is on USB 2.0 - if it's reading the 2GB drive, could it be that the 320GB one is just too big to read...even though I hardly have much on it? Or maybe I just need to reformat the 320GB drive?
SOURCE: WD External Hard Drive 320GB Cyclic Error
Windows Delayed write file error
Read this
http://support.microsoft.com/kb/330174
since your talking about the External drives, a lot of reasons makes this happen. if the resolution above link cant help you, then try this:
Make sure that update the driver of your PC hard drive. Usually, this errors appear if your moving from one hard drive brand to another ex: seagate to samsung etc....
updated hard drive driver resolve this.
Make sure the cables are alright. Or at least have the latest service pack. USB drivers causes issues as well. I updated mine and the problem did not crop up anymore. hope this would help.
SOURCE: WD portable hard drives not recognized
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external ,
go to Start-Control Panel-Administrative Tools-Computer Management-Disk
Management , and see if your external drive is listed here with your
local drives. If it is listed , right click on the drive and change the
drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your
computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your
computer case or another external case.If the drive works , the problem
is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
The
latter is the easiest to diagnose , does your external light up at all
when you plug in the power? If not , then this is probably your problem.
On the bottom of the adapter is a label which you will be able to use
to have a new adapter made at your local electronics shop and this will
cost about $30 max. They will also be able to test the adapter with a
clamp meter to see if this is really the problem and this should be
free.
The second component you want to test is the USB cable. If
you have a printer , swop out the cables and see if your printer
functions normally. Most externals use the same connector so you should
be able to test it in this manner. If the cable works go on to the last
step. If the cable is defective , replace it with a new one which you
can find for about $10 at most electronics and chain stores.
The
last component to test is the circuit board. This is a bit of a grey
zone as you probably won't be able to spot the blown component unless it
failed really badly. With the casing already opened , locate the
external's circuit board and check to see if you have any blackened
components or fluids leaking from some components. If all the other
components of the external worked perfectly , then this is the faulty
part. It is not really economical to replace the circuit as most of the
time it is out of production by the time you need to replace it and it
still costs a lot even if it is available so if your drive is working
perfectly when connected via sata or IDE on your computer , the best is
to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
SOURCE: How do I disconnect (uninstall) a WD External Hard
External hard drives don't need any program installed on your computer to run. Your operating system Windows, Linux should handle it as soon as you plug the usb in your computer. The programs included in your WD external hard drive are tools to backup your data.
If you try to hook up your hard drive to a Windows prior to XP, maybe your computer will not handle it.
It is always safer to safely remove your drive using the green arrow icon in the lower right corner of your screen. This way, the drive is shut down properly and you minimize chances of fails when you plug it again on another computer.
Hope this helps!
