Have you had it repaired recently? Internal Error usually shows up when the digital board has been replaced and the new one has not been correctly set in the region code selection.
It's not really something you can do at home. You have to solder a jumper onto the digital board and make the settings and then remove the jumper. Not something you want done my someone who is not a pro. I would take it into a shop and let them do it.
are this Jumper the Pull-up resistors? R754 10k and r760 47k? (Europe, XR-V763) How to set it after soldering?
oops, R754 right?
Check to make sure that the receiver speaker switch is set to the "on" position. I had a receiver that indicated an "overload condition" when there was no load on the output circuits.
SOURCE: HTMI errors on the following devices
You have to use Component Video on this unit. HDMI will not "Handshake" and pass thru. This was HDMI's first version "1.1a" and there is no fix. Use your receiver to switch audio via Coaxial or optical then use HDMI directly from BLURAY etc to your TV. The downside to this is how many HDMI inputs your TV has. It's an awesome receiver! Don't blame Yamaha!!! This issue is directly attributable to "HDMI" and their race to shelves before truly field testing the product. The current version of HDMI is 1.3b and soon to be 1.4 which includes ethernet capabilities.
I hate to be the bearer of bad news! If you would like an "in depth" look into the world of HDMI issues, Google HDMI problems or HDMI forums, and you can read for hours. Hope this helps
SOURCE: Yamaha htr5730 receiver - turns off
You may have speaker wires touching each other or a short circuit in the wire. "Check SP Wires" means to check your speaker wires.
SOURCE: Yamaha RXV661 Receiver has Zone 2 Vol Fix error message
i have the same problem. i have a rx-v661. i goto the zone 2 settings and try to change the volume and it says VOL FIX. I cannot hear anything out of zone 2. It takes the current volume that is in zone 2, but i cannot hear anything. it has been working fine for at least a year.
