Hi,my belling model 664 wh is tripping out just as it reaches set temp on main oven dial,i have just replaced the main oven element, any solutions I would be grateful. Thank you.
Sounds like the amperage draw of the oven is right at the breaker size. Circuit Breakers should not be loaded more than 80%. Breakers take time to trip when they are close to the limit. IF the problem started with the replacement oven element, it may be the wrong one and could be tripping the breaker by drawing too much power.
Otherwise: Wiring or breaker not sized right, maybe another load on the breaker in addition to the oven, possible bad connections causing extra amperage, or wrong the oven element made for a higher amperage oven. In rare cases the breaker might be bad, but this is not likely.
Someone experienced needs to a) identify the breaker size b) verify the wire connected is appropriated sized c) verify the oven's current requirements and d) look for bad connections.
Normally another load would not be on the oven circuit unless a diy person changed the wiring. With those items verified, a clamp on amp meter would be used to verify actual current draw when the oven is on to ensure the load is appropriate for the breaker, wiring and oven. If at this point the load is less than 80% and the breaker still trips, change the breaker.
