After the door is closed and the latch secures, the Normal cycle light flashes and a beep tone sounds continuously. Reset stops it for a short period then problem resumes
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
I had the same blinking light. My immediate attempt was to open and close the door. This did not help. I checked the pop up sprayer and it was not blocked. I checked and the soap door was open and would not latch. I closed the main door and pressed start/reset and the normal light stopped blinking. After that, I checked the soap door and saw that it bound a little, but still didn't latch. Right now I'm running a "rinse and hold" to see if it clears the fault, which I think is a problem with the soap door and the soap pod I had used. Anyway, use this as a starting point. The normal light blinking means that the sequencer board failed a test, which could be anything from a loose connector or ground wire to a failed component. Good luck!
