Oven stops heating sometime during the cooking process. It heats up fine, but then at some point it stops heating.
SOURCE: Kitchenaid Superba gas stove. Oven
so you get an error message on the display?
do the burners work?
SOURCE: gas oven makes a fluttering sound when pre-heating and cooking
This is most often due to the ignitor bar aging. With time it draws less current and does not hold the regulator valve open all the way. You can confirm that the regulator is OK if the broiler works. Replacement for nearly all of these ovens is a universal part, about $35 at appliance parts stores, takes 5-15 minutes to change (depending on whether you need to pull the oven out to get to the connector).
SOURCE: the oven does not heat up. broiler and cook top is working.
Check to see if the oven elements work, take out the racks and check if the black tubes on the top and bottom have ripped.
SOURCE: Superba KGT607HBS oven stopped working
The flame went out. Move the oven control back to where it sounds like it is lighting. After it clicks a few times and sounds like you have a flame set your temperature again.
SOURCE: oven wont heat up
Most likely the problem will be in the control unit. Something is stopping the relays for the oven and broiler from working.
This site has a diagram of your range and a price for the part.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=264337&diagram_id=123066#d123066
