Original owner let it run low on fluid because of leak. ... The worn bores will cause slipping, hard shifts, and high revs between shifts from those gears. ..... Andy I bought a 02 mercury mountaineer v6 4.0 the the O/D flashes and service light is on ... Get on a flat surface at highway speeds and manually turn the OD of and on.
the od light flashing is an indicator that there is a problem in the transmission hook up a scanner to get the codes first it will give you a direction as to where to look for your problem
The flashing light means there is a system problem with the automatic transmission. You will probably notice a lack of power when starting from a stop with this lamp flashing. The dealer or local mechanic should be able to scan for a fault code.
The flashing OD light indicates there is a problem in the transmission control system. When the Transmission Control Unit detects a malfunction it will flash the OD light and store a Diagnostic Trouble Code (DTC) in the computer. You will need to have a Ford Dealer pull the codes and determine exactly what is wrong.
I wish I could be more specific, but there are about 120 different reasons for the flashing OD light.
The OD light is flashing to alert u to the fact that some kind of fault has occured in the transmission, the problem is in many cases a slipping condition, you need to have the trans control system tested for the trouble codes that are stored when this light flashes, this will let u know what the problem is and a direction to follow to repair it.
this could mean there is a problem with the transmission,but most times when OD light is flashing it is because the wiring to the OD switch is broken.
is the OD switch on the end of the gear shift lever ?
or does your vehicle have the shifter on console between seats ?
