I can't seem to find info on this preamp but, that sounds like a power supply problem, considering, the tuner is the part of the circuit that would need power. Volume and tone controls don't, unless they are active,(which I've never seen a reason for). I would try a new battery, because I think you left it on overnight, check the slot for corrosion or a loose wire or connection.
SOURCE: Hello, I have found that Ibanez
There is little data on the internet about this... However my AEL20E uses 2 AA cells. Some older ones may have used a 9 volt battery. Yours should use the 2 AA cells which go into the box right by the XLR output plug.
SOURCE: Hi, My Ibanez AEL 20
Ibanez V72ECE hey i bought new ibanez and the tuner not working, i bought new batteries but still cant run. maybe its some way to activate it or its just bad one? [email protected] plx helpme
