Toshiba Satellite 1135-S1553 Notebook Logo
Y
Yuri Posted on Dec 02, 2013
Upgrade cpu processor
Hello! I mounted the processor Pentium 2,4 hGz. Runs on 1, 2 hGz. Why?
1 Related Answer
Thomas F. Schneider
  • 2715 Answers
  • Posted on Jan 18, 2009
SOURCE: Slow running Satellite A135-2276 even after installing 2 GB memor
I  believe you stil must have somethinfgg amis in the OS, since no excess services are running  . I would obtain the CD and reinstal then reinstral the new drivers again.
2helpful
2answers
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
2helpful
4answers
Can i up grade my single core cpu pen4 550 3,4GHz to a Quad core or dual core either one would help
Depends on the socket type.. Socket 423 and 478 do not support core duo or quad core processor types. However, if you have LGA 775 (aka socket T) your motherboard will support the following:
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition (3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition (3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
3helpful
2answers
Pentium 4 upgrade
The Compaq Presario SR2011WM supports following processors:
CPU/Processor
  • Socket: 775
  • Supports the following processors:
    • Pentium D 900 series Dual Core (Pressler, 65nm)
    • Pentium D 800 series Dual Core (Smithfield, 90nm)
    • Pentium 4 601 series (Cedar Mill, 65nm)
    • Pentium 4 600 series (Prescott, 90nm)
    • Pentium 4 500 and 501 series (Prescott, 90nm)
    • Celeron D series (Prescott, 90nm)
Hope it helped.
3answers
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
7helpful
2answers
I want to upgrade my hpdv1000 pentium M processor whats the maximum upgrade allowed for this? i have upgraded it to 2gb ram from 512mb and 250gb hd from 60gb and its doin fine.
You should be able to upgrade the CPU, since it seems that the DV1000's motherboard uses a socket CPU design. But, obviously, HP would rather have you choose the CPU that you want from the beginning and stick with it.
The first thing to do is to check HP website to see what other configurations were/are sold for your model. If they sell it with faster CPUs then you can upgrade to one of them...
PLEASE NOTE:
In order for a particular processor to be compatible with a particular laptop:
(1) the processor must be physically compatible with the laptop socket, in your case I thing you have a Soket 479 processor
(2) the laptop chipset must support the processor.
(3) the chipset front side bus speed must match the processor front side bus speed, in your case 400Mhz.
(4) the laptop BIOS must support the processor.
So I listed here processors with FSB at 400Mhz, I gues that DV1000 as a 855GM Motherboard that supports only 400Mhz with Socket 479
Pentium M
Banias
Pentium M 1.3 1300 1024 400
Pentium M 1.4 1400 1024 400
Pentium M 1.5 1500 1024 400
Pentium M 1.6 1600 1024 400
Pentium M 1.7 1700 1024 400
Dothan
Pentium M 710 1400 2048 400
Pentium M 715 1500 2048 400
Pentium M 725 1600 2048 400
Pentium M 735 1700 2048 400
Pentium M 745 1800 2048 400
Pentium M 755 2000 2048 400
Pentium M 765 2100 2048 400
Celeron M
Banias-512
Celeron M 310 1200 512 400
Celeron M 320 1300 512 400
Celeron M 330 1400 512 400
Celeron M 340 1500 512 400
Dothan-512
Celeron 205 1200 512 400
Dothan-1024
Celeron M 350 1300 1024 400
Celeron M 360 1400 1024 400
Celeron M 370 1500 1024 400
Celeron M 380 1600 1024 400
Celeron M 390 1700 1024 400
Best Regards
2helpful
I want upgrade
hello, i would install the cpu you wish to use, then see how it runs. and then do a bios update. this may work,if not the motherboard may not be compatible with the cpu upgrade, (propriatory equipment sometimes does not allow such upgrades) like hit or miss! i hope this info helps,and you get the dell to accept the faster cpu. good luck! glen
UpGrade
you could only upgrade the processor and RAM in this condition i.e.
you can only change your an upgraded p-III processor like 1.0 GHz, 1.1 GHz or 1.3GHz and
upgrade the RAM by changing to 256 in each slot.
that is all what u can do with ur pc
Processor
I told you my opinion, If I was in your shoes I won't upgrade the CPU.Professionals do not do works against Factory specifications, and I fixcomputers for living.
Acer says Pentium dual is not supported on Acer 4315, I can only tell you not to do such an upgrade.
Itwould be the same as if you ask me if you can mount a Jaguar engine ona Mini, yes, for sure there is the way to mount it, but the car won'twork as it is supposed to, and risk to blow at first corner.
If you really want to replace your CPU consider the following.
Acersays pentium 2 dual core is not supported on 4315, if you do ityourself you risk to damage the computer. Do not do the CPU upgrade ifthis is your only laptop, or if you care of this laptop, chance ofdamaging laptop are high. This kind of upgrades are done more as anexperiment.
I know Core 2 Duo T5300 1.73 Ghz had been installedsuccessfully on Aspire 4315, Acer says not to install any core duo, Iknow for sure Pentium duo T5200 1.6 Ghz works on Aspire 4315 with noneed for replacing cooling system.
Both chipset are difficult to find, best place to find them is Ebay.
Check this link for an extensive report on this matter:
check also: Is it worth upgrading the CPU on Acer Laptops?
CPU Upgrade
you should upgrade computers, because a pentium 2 and 3 wont do ****.
2answers
Upgrade from 600 MHz to 1 GhZ
According to this review, you can upgrade as far as a 2 GHz P4-M at least; http://www.pcmag.com/article2/0,1895,669029,00.asp Other than that, i have been unable to find the details of your motherboard - if you can post the make and model (should be printed on it somewhere) then I would hope to find a more complete list of compatible and incompatible processors. Gateway themselves no longer offer online info or support for this model, but the motherboard details should enable me to find out what you need to know. Waiting for your post :)
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
