C3D2
EPU board memory old parts detection error: The EPU board cannot detect the new process unit when the equipment is started in the EPU replacement mode ([7] + [START]).
C410
Thermistor or heater abnormality at power-ON: Abnormality of service call the thermistor is detected when power is turned ON or the temperature of the fuser roller does not rise in a specified period of time after power is turned ON.
C430
Thermistor abnormality after abnormality judgment: Abnormality of the thermistor is detected after a specified period of time has passed from power-ON (including ready state).
C440
Heater abnormality after abnormality judgment: The temperature of the fuser roller has exceeded the range of control or does not even reach the range.
C450
Thermistor abnormality during printing: Abnormality of the thermistor is detected during printing.
C4C0
Fuser unit new/old detection fuse abnormality
C550
RADF I/F error: Communication error has occurred between the RADF and the scanner.
C551
Document feeder model detection error: An optional document feeder that is not compatible to this equipment is installed.
C570
Communication error between Engine-CPU and IPC board
C580
Communication error between IPC board and finisher
C5A0
EEPROM communication abnormality (LGC board)
C8E0
ADF communication abnormality: The system has to be stopped because the control abnormality occurred
C940
Engine-CPU abnormality
C970
High-voltage transformer abnormality: Leakage of the main charger is detected.
CA10
Polygonal motor abnormality: The polygonal motor is not rotating normally.
Hi Zihaalsan, the link below is a user manual showing error H4 and solving the problem... Good luck......CHEERS.. http://olsonbros.com/sharp/support/pdf_trbl/trbl-arm160_m205.pdf H4. Heat roller low temperature detection...
When the fusing temperature is lower than 150C° after 55sec from the start of warming up. When the warming up complete temperature is not reached in 30sec from reaching 150C°. When the fusing temperature is lower than 100C° after 20sec from ready start. When the fusing temperature is lower than 145C° when printing." Cause Thermistor abnormality Heater lamp abnormality Thermostat abnormality Control PWB abnormality Check and remedy Use SIM 5-02 to check the heater lamp blinking operation. When the lamp blinks normally. Check the thermistor and its harness. Check the thermistor input circuit on the control PWB. When the lamp does not light up. Check for disconnection of the heater lamp and the thermostat. Check the interlock switch. Check the power PWB and the lamp control circuit on the MCU PWB. Use SIM 14 to clear the self diagnostic display.
Cause: Thermistor abnormality Heater lamp abnormality Thermostat abnormality Control PWB abnormality Check and remedy Use SIM 5-02 to check the heater lamp blinking operation. When the lamp blinks normally.
Detail When the fusing temperature is lower than 150C after 55sec from the start of warming up. When the warming up complete temperature is not reached in 30sec from reaching 150C. When the fusing temperature is lower than 100C after 20sec from ready start. When the fusing temperature is lower than 145C when printing."
Check and remedy
H4 00 Content Heat roller low temperature detection Detail When the fusing temperature is lower than 150Cafter 55sec from the start of warming up. When the warming up complete temperature is not reached in 30sec from reaching 150C. When the fusing temperature is lower than 100C after 20sec from ready start. When the fusing temperature is lower than 145Cwhen printing." Cause Thermistor abnormality Heater lamp abnormality Thermostat abnormality Control PWB abnormality Check and remedy Use SIM 5-02 to check the heater lamp blinking operation. When the lamp blinks normally. Check the thermistor and its harness. Check the thermistor input circuit on the control PWB. When the lamp does not light up. Check for disconnection of the heater lamp and the thermostat. Check the interlock switch. Check the power PWB and the lamp control circuit on the MCU PWB. Use SIM 14 to clear the self diagnostic display
H4 00 Content Heat roller low temperature detection Detail When the fusing temperature is lower than 150C° after 55sec from the start of warming up. When the warming up complete temperature is not reached in 30sec from reaching 150°. When the fusing temperature is lower than 100C° after 20sec from ready start. When the fusing temperature is lower than 145C° when printing."
operation. When the lamp blinks normally. Check the thermistor and its harness. Check the thermistor input circuit on the control PWB. When the lamp does not light up. Check for disconnection of the heater lamp and the thermostat. Check the interlock switch. Check the power PWB and the lamp control circuit on the MCU PWB. Use SIM 14 to clear the self diagnostic display. Good Luckdo rate the solution if got help
H4 00 Content Heat roller low temperature detection Detail When the fusing temperature is lower than 150C° after 55sec from the start of warming up. When the warming up complete temperature is not reached in 30sec from reaching 150C°. When the fusing temperature is lower than 100C° after 20sec from ready start. When the fusing temperature is lower than 145C° when printing." Cause Thermistor abnormality Heater lamp abnormality Thermostat abnormality Control PWB abnormality Check and remedy Use SIM 5-02 to check the heater lamp blinking operation. When the lamp blinks normally. Check the thermistor and its harness. Check the thermistor input circuit on the control PWB. When the lamp does not light up. Check for disconnection of the heater lamp and the thermostat. Check the interlock switch. Check the power PWB and the lamp control circuit on the MCU PWB. Use SIM 14 to clear the self diagnostic display.
H2 00 [Content] Thermistor open [Detail] The thermistor is open. The fusing unit is not installed. Cause Thermistor abnormality Control PWB abnormality Fusing section connector disconnection The fusing unit is not installed. [Check and remedy] Check the harness and the connector between the thermistor and the PWB. Use TC 14 to clear the self diagnostic display.
To enter the serviceman test command mode, press the keys as follows: [#] key → [*] key → [C] key → [*] key Enter 14 Start to clear the code.
H2 00 Thermistor open detection
