If the touchpad on your GE Cafe over-the-range microwave has stopped making beeping sounds, there could be a few potential causes. Here are a few troubleshooting steps you can try:
Check the volume settings: It's possible that the volume settings on your microwave have been accidentally turned off or lowered. Look for a "Volume" or "Sound" button on your microwave and adjust the settings as needed.
Check for a mute function: Some GE microwaves have a "Mute" button that allows you to silence the beeps temporarily. Make sure this feature hasn't been activated.
Power cycle the microwave: Turn off the power to your microwave for a few minutes, then turn it back on. This can sometimes reset the touchpad and restore functionality.
Check for error codes: If there's a problem with the microwave, it may display an error code on the control panel. Look in your user manual or search online for information on what the code means and how to resolve it.
Call for service: If none of these steps work, there may be a problem with the touchpad itself. Contact GE customer service or a professional appliance repair technician for assistance.
I Believe this model has an options button with codes by numbers which are 1 thru 6 I believe. Either 1 or 2 are sound. So hit the options button and hit the number 1 it should say (sound), Then you will hit 1 again a.k.a. mute, and no more beep beep beep. If 1 is not sound then you may have accidently created a small but deadly emp, so hit stop and you must hit options and then hit 2.
If the owner's manual doesn't offer that as an option, there are three ways: - desolder the piezoelectric element (beeper) - cut one of both of its leads - snap it out of the circuit board (see video)
It sounds like the thermal fuse may be defective, or the fan is not running, or the magnetron is getting to hot. If there are any heat issues the thermal fuse will cut power and reset in 5 minutes.
