Maytag MMV4205  Microwave Oven Logo
A
Anonymous Posted on Dec 02, 2013
Mounting template for MMV1153BAS
I need a mounting template for upper and rear for this microwave.
1 Related Answer
Anonymous
  • 159 Answers
  • Posted on Mar 03, 2011
SOURCE: The instruction manual was not in the box when we
run a search for maytag microwave model mmv1163dwoo, then scroll down to installation guide/manual, it was at www.managemylife.com, page 7 in the manual, I believe.
1helpful
I'm installing a GE spacemaker JVM130K but don't have the mounting templates where can I find them?
I checked the manual and it did not provide one or mounting dimensions. If you already have the unit, reverse engineer a template... You can either do it by holding paper to the sides and marking the mounting points, or simply take the measurements for the mounting points from a good known reference - such as the front if you are looking to moun the front flush to the face of the cabinets.
Need Installation 'Paper' Template for MMV4184AAW Maytag Microwave
see the video
and proceed according. God bless you
Over The rang microwave installation
I would say finish the wall, because the microwave needs the space for cooling.
LG LMV1680ST no upper mounting
Look for back mounting bolts location, find your wall studs location and mount from the back
Can you provide guidance on how to install this microwave? Trying to decide if I should pay $120 for the store to install.
Installation of an over the range microwave is not a very difficult task as long as electrical work to provide power is not needed. If no outlet exists then an electrician will be required.
Tools that may be needed for the installation include a cordless drill, drill bit, measuring tape, masking tape, stud finder, razor knife, pencil.
A template is commonly provided for mounting hole locations that need to be drilled in the cabinet. These holes are the top mounts.
An additional template for the wall bracket is normally supplied as well. Here you will need the stud finder, it is important to locate the studs and mount the wall bracket to them.
The wall bracket serves as the bottom mount and aids in the final mounting of the microwave.
Depending on the oven's size and weight a helper may be needed to complete the installation.
Remember to be safe first and seek advice/help with any step you are unsure about.
Good luck.
2answers
Hi there, I'm installing an LG LMV205SW OTR Microwave and the four holes for the mounting plate do not coincide with the two wall studs that are behind the microwave location. Can I sink a couple of extra...
Consider the studs as I I add 2 2x4's like in an H with second 2x4 below the cenre bar in the H adjust both to the spaces needed for your mounting crews if it came with a template use it....I am not a carpenter but It Is what I would do
When installing over the range microwave does template need to be removed
the paper template that they send to mark for mounting instructions? yes...another template you're refering to?
3helpful
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
LG LMV1680BB top mount not usable
They simply need to drill new holes, I'd say.
The installation instructions will have a template.
2helpful
2answers
How can I install this oven GH9115XE?
You may be looking for this flat head 1/4 x 28 threaded bolt that is about 4" long. The tip of the bolt does not have threads, which aids in locating the threaded holes in the top of the microwave:
GE # WB01X10180 (or AP3205964 or 942461 as listed on some repair parts sites)
or a set of three
GE # WB01X10125 (or AP3185225 or 910236 as listed on some repair parts sites)
Top Maytag Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
