Belkin Pre-N 802.11g/b Wireless Adapter Logo
Anonymous Posted on May 10, 2009
Belkin 802.11a/b/g usb adapter
Im useing this usb adapter from my bedroom next to the dining room to connect to our belkin wireless 802.11g router the signal strength is excellent its always at 54mbp but it wont connect to my network or any other network for more than a few seconds and frankly its begining to **** me off. If there is someone out that with an answer to this id very greatly appriciate the reply, unless of course this technology is a total POS
Thanks For Takeing The Time To Read This
Kevin
  • Anonymous May 10, 2009
    Thanks Alot Ill Give It A Go :-) And With A Bit Of Luck It Will Work
Anonymous
Level 1:
Problem Solver:
  • Contributor 16 Answers
  • Posted on May 10, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
16
Questions
0
Helped
23166
Points
41
It sounds like the plug on the USB wireless dongle is bad or the usb ports in your computer are having problems. My Toshiba notebook does the same thing with the two usb ports near the front of the computer but works fine from the two on the back. When you have a flash drive plugged into the USB do you frequently get the new hardware found message as if you had unplugged and replugged the drive? If you have a powered external USB hub try plugging that in first then when that is stable plugging the USB wireless dongle into the hub rather than the computer. If it is stable then the problem is on the power pin in the USB port of your computer. Good Luck
2helpful
Installed Belkin Wireless USB adapter. Didn't
Connect with the Ethernet and maybe windows has an update driver for it.
2answers
We formerly used a linskys router, How can we
if you have not changed any settings from belkin router, access the wireless configuration on your windows machine and search for the belkin ssid then hit on connect
1helpful
Trying to create a bridge with two routers
You do not need a bridge if you are using a wireless adaptor on your pc in the other room. Just set up the Belkin Plus router to the WEP security settings you want and make sure the pc wireless usb adaptor has the same settings as the router. You should be good to go. Good Luck.
2answers
Trouble expanding my Belkin Powerline network
F5D4075 uses Homeplug AV standard and F5D4071 used Home plug 1.0 Turbo. Both are not compatible to each other. So if you form a network, you have to form with the same standard.
Secondly, You need just one Powerline adapter on the router and you can have 2 or 3 adapter connected to 1 computer each and all these computers can connect to the 1 adapter on the router. You do not have to use it in pairs
Bellkin G+ Mimo usb adapter - invisible
Use this tip as a check list.
Check if you set the correct SSID + Key and "connect if router is not broadcasting" set in your adapter configuration.
If you do not know Key you need to reset from Router.
If you missed SSID you can check on any PC when connected to WLAN and retrieve the name of NON BROADCASTED network
Wont work my belkin usb
All wireless adapters use the same radio channels so your adapter will work with your router. (If that wasn't the case, it wouldn't be so easy to connect to networks with a laptop with built-in wireless.)
3answers
Belkin Wireless G USB Network adapter 802 11g password
give me the model and brand of your router. The key is in the configuration page of your router. email me at [email protected]
Connecting belkin router
Hi!
How far are you away from the router to the bedroom?
What do you mean by "bedroom system"? Is it a wireless computer?
1helpful
2answers
Belkin wireless G USB adaptor 802 11g
Correct installation of this cheap little piece of kit from Belkin might be the worst thing you ever do! If you find that Windows XP is freezing 10 times per day, just remove the wirelss adaptor and you will find that the problem disappears... The conclusion will be as obvious to you as to many other users.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
