Mother gave me her KIRBY model 293501 with no directions how can I obtain this manual, how to use as carpet & upholstery cleaner, how to use all attachments, list of attachemnt I should have, basically I have the machine and want to use it to its full capabilities-THANK YOU SUSAN READY 781-075-0975
Is this what you are looking for?
http://kirbywhq.powweb.com/manuals/UltimateG/77A0CF1A5F7DB07CF87DB5A31B84CF28/UlimateG.pdf
SOURCE: Cleaning upholstery with the Kirby?
it depends on the make of the kirby you are using but most kirby systems come with a portable shampooer and special shampoo. I would not recommend using your zip brush for shampooing purposes, the zippbrush is designed to loosen up dog hair, dirt, ect. when vacuuming. to shampoo upholstery do the following: remove bag from side of machine, place hose where bag goes, remove power head from front of the machine, place air intake valve on front of machine where power head was (intake valve kinda shaped like a pig nose with small holes on end) attach portable shapooer to end of hose and fill with water and kirby shampoo spray shampoo witch is foamy looking on whatever you are shampooing, rub into fabric w/a brush and let sit till dry. when dry turn kirby back into a hand held vacuum by putting powerhead back on front of machine and putting bag back on side of machine, then vacuum furiture. (make sure it is 100% dry before you vacuum because Kirby is not a wet vac!) Hope this helped ya out a little
SOURCE: how do i attach my upholstery cleaner to my kirby generation 4?
Upholstery shampoo manual HERE.
Good luck,
Rocky
SOURCE: How do I connect upholstery cleaner to Kirby Sentria
Here is a link to available owners manuals...
http://stores.shop.ebay.com/CLICK-HERE-FOR-GREAT-DEALS_KIRBY-OWNERS-MANUALS_W0QQ_fsubZ7656839QQ_sidZ122982163QQ_trksidZp4634Q2ec0Q2em322
Hope this helps,
Marci
