SOURCE: Probleme avec ma carte son
I made a downgrade on HP Pavillion Notebook and no more sound is going OUT. My notbook is Compaq Presario V3772TU Notebook PC THE PROBLEM seems to be on the CONEXANT HD AUDIO IN / Driver... can you help here...I need the XP drivers I guess....where the hell can I find them
SOURCE: ERREUR FDC FAILURE
FDC == Floppy Disk Controller
The FDC controls the 3.5-inch diskette drive.
Check that the drive is getting electrical power,
and that the ribbon-cable from the motherboard is connected to the drive.
Or, press F1 to enter BIOS SETUP, and select "disable" to block all usage of the 3.5-inch diskette-drive.
SOURCE: Je possède une jetta 1997.
IMPORTANT NOTE: You must have the security anti-theft code for yours Audi Concert radio from the car manufacturer! For Audi Concert the sequence of programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
3. By the #1 key you will set up the first safe code digit.
4. By the #2 key you will set up the second safe code digit.
5. By the #3 key you will set up the third safe code digit.
6. By the #4 key you will set up the four-th safe code digit.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed. The radio is now ready for use!
SOURCE: BONJOUR,J,AI UN TROUBLE AVEC 1
Hello, welcome to Fixya!
Please can you rephrase your question in English?
I look forward to your reply.
Bye for now.
