Kodak EASYSHARE M1063 Digital Camera Logo
Posted on May 10, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I GET DATE AND REGULAR TIME, NOT MILITAY TIME, ON PICTURES
Very little instructions on how to set up anything with camera. brought camera and took to graduation with our daughter, took long shots but they are so dark we cannot see anything. outside pictures are great but no date or time on them and not too much instructions on how to put on pictures.
Vitally Alcher
Level 3:
  • Master 1,645 Answers
  • Posted on May 15, 2009
Vitally Alcher
Master
Level 3:
Answers
1645
Questions
Helped
466807
Points
3209
Turn camera ON
Scrol with Menu Burtton to time and date .
Scroll far right and set time and date.
When taking pictures put on the Beach or Snow mode.
Vitally
Is it possible to stamp date and time on pictures using a kodak cd82 camera?
To set the date and time on your camera, follow these steps:
Turn on the camera and set the language and date/time by following the instructions in the Extended User Manual.
Once you have set the date and time, you can turn on the Date Stamp feature by following the instructions in the User Manual . The date and time will be stamped on all pictures taken with this feature enabled.
KODAK CD82 - EXTENDED GUIDE EXTENDED USER MANUAL Pdf Download ' ManualsLib
KODAK EASYSHARE CD82 USER MANUAL Pdf Download ' ManualsLib
Pentax k2000 won't save time and date
In most modern cameras is a little rechargeable battery, that keeps the clock ticking. If your camera was a long time without power, perhaps this battery has died. I would buy a new set NiMH rechargeable or recyclo batteries, because they have a bit less capacity, but can hold power for as long as a year. Then charge them and leave the rechargeable batteries in your camera. Keep your fingers crossed, perhaps the little clock battery will be revived?
Please tell me how to have my C182 print the time and date on the picture..................
Hello and Welcome to FixYa!
To set date and time on pictures.Follow the given instructions:
  • Turned ON the camera
  • Press MENU, Use Left or Right key to select Setup
  • Use Up or Down keys to select Date & Time
  • Use Left or Right key to move between fields and also press Up or Down keys to change values.
  • Now Press OK to accept.
After it time and date will automatically set on the camera and it will be print on your pictures too.
I hope this solution helps you
Thanks and Keep using FixYa
6helpful
2answers
How do I set the date and time spamp on a Canon A490
To set the date and time stamp on pictures, Follow the given instructions:
Setting Date and Time:
First of all set the exact and time if your camera:
  • Press the "Menu" button on the camera and use the right navigation button to choose the "Set Up" menu.
  • Scroll down to "Date/Time" and press the ""Func./Set" button. The set date and time will appear on the screen, and the month unit will flash.
  • Adjust the month unit by pressing the up or down navigation buttons. Move to the day unit by pressing the right navigation button. Use the same instructions to adjust each unit of the date and time.Push the "Func./Set" button to save the time and date settings.
Setting Date Stamp on pictures:
  • Press the "Func./Set" button and select "Recording Pixels" and "Postcard". The camera is now set to "Postcard" mode.
  • Open the "Rec." menu by pressing the "Menu" button on the back of the camera.
  • Highlight "Date Stamp" by pressing the down navigation button.
  • Change the "Date Stamp" setting by pressing the right or left navigation button. Your choices are "Off", "Date" or "Date/Time". Now, when you take photographs the date or the date and time will appear on the picture.
If this solution helps you then your token of appreciation in the form of Rating as Four Thumbs and a testimonial will be esteemed.
Thanks you for using FixYa!
If i put my camra on self timer win i print the pictures will the time show up on the pictures
The time it took the picture? You want to know if the camera will show the time it took the picture using the self timer?
My answer is Yes and No.
Do you have your camera set to showing the date and time on the pictures now? If you do, then using the self timer would not change anything.
If you do have it set to showing on the picture and you don't want the date and time to show then change the setting on the menu function of the camera and turn this option off.
If you do not already have the camera set to show the date and time, using the self timer option is not going to make it suddenly appear.
Setting date and time on photo
As long as the current date and time are set correctly, the camera will always store the date with the picture. If you want to print the date with the picture, please refer to the documentation for whatever program you're using for instructions.
28helpful
2answers
How to set date stamp for canon ixus 860is
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
dsc_include_date01_tcm13-520510.jpgTo set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm13-520511.jpgBe aware that if you take pictures with this option enabled, the Date and Time cannot be removed from the pictures at a further time. It will permanently appear on the picture.
Please rate my help++++Thanks for using FIXYA
1helpful
How do I set the date and time on my Panasonic Lumix LZ2 Digital Camera
Hi there.
You will find time and date in the settings menu on the camera.
Good luck and thanks for using FixYa!!
Have to reset date every time I turn on camera.
You need to replace the date battery. It's a button-type battery (CR1220) which is in a holder near the regular batteries. After you pull the holder out, place the new battery into the holder with the negative side up, and slide it back into its slot. (Instructions are on page 120 of the manual if you have it.)
Camera not displaying pictures
I was fighting with a Scanner and camera Wizard issue in XP and looking at all kinds of sites, forums. One that came up was someone had a similar problem to yours and had to go into Norton and uncheck removable drives to get the drive to show up. Also check the microsoft site for fixes, patches for ME. On my problem the drive wasthere but the wizard would not open and someone suggested to remmove Realplayer. It worked!!
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
