Water is reaching the bathroom fine it will just not go through the faucet
SOURCE: low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
SOURCE: DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
SOURCE: my bathroom faucet wont turn off. I can turn the
Hi, W/D here.
You'll need to shut the water off under the sink. Usually when the water won't shut off, the washer (or cartridge) is damaged or loose. With the water shut off, open the valve. Remove the handle and trim piece that surrounds the stem. With a wrench or socket, remove the valve cartridge from the body. The part that you need to unscrew isn't the first nut that you see when you look down the shaft, but rather, the ut just past that. The first nut is the packing gland adjustment, the second holds the two halves of the valve together. Usually, it isn't hard to get these apart. Pull the part out of the valve body and check the washer at the base of the stem. It is probably loose. Tighten it back down, or if it is damaged, replace it. While the valve is apart, stick your little finger in the valve hole and feel the valve seat. It should feel smooth and free of nicks and grooves. Should you need any parts, you can take your old parts with you when you go to the hardware store, and match them up. If the seat is damaged, you may need a 'seat removal tool' also available at the hardware store. A washer is the easiest repair. If the damage is much worse that thet, consider a repair kit. I will have the upper valve assembly that you pulled out, washer and replacement seat, along with the gaskets.
Reinstall your valve, making sure that the stem is backed out as if full open. If you put the valve assembly together with the valve stem 'closed', you can damage the washer. Once all back together, adjust your packing gland. It should be adjusted to be just tight enough to keep water from flowing out alongside the valve stem without being difficult to operate. Reassemble the trim, replace the handle. Close the faucet valve and open the water supply valve. That should do it.
Best regards, --W/D-- please feel free to rate this solution -- thanx!
SOURCE: I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
SOURCE: i HAVE A SINGLE HANDLE HIGH NECK BLANKO KITCHEN
If water come out the faucet hot line,check if is clogged.For this job you need to disassemble the faucet.
Here is a good PDF source to do it.
If you need more help come back.Post / thumbs / testimonial are welcome!
