When i press the power button nothing appears but a black screen.so i just let the battery die but when charges and when the metro says ''hello hello wireless for all'' it doesn't appear just pure black but the keys light up but that mostly all
SOURCE: Razr won't power up.
SOUNDS LIKE YOUR SCREEN HAS BLOWN BUY A NEW ONE THERE ALL THE SAME THE RAZORS DONT LAST FOR 2 SECS
SOURCE: Won't Turn On/Charge
when that happened to me it could have been caused by two possible problems:
1) water damage. If you know it's not water damage, it still could be because if you had your phone in the bathroom while having a shower, steam can seep in and if it's one thing I noticed about chocolate flips they get water damage really easily.
------>>> If that is the case then you have to take your battery off and take a really fine ground sand paper and rub along the contacts (like the copper that is on the battery and the phone that touch when you put ur battery in) and that will rub off any kind of oxidization (rust) and possibly make your phone work. It happened to mine and I did that and it was successful
2) you could not be turning your phone off regularly enough. Technically, you are supposed to turn your phone off every night when you go to bed to give your battery time to re-vamp. Also, I was speaking with a rep from telus and they were saying that you should also turn your phone off during the day, just for a minute then turn it back on again and apparently it recharges the battery as well.
Hope this helps!! It only comes from personal experience so it all depends on the reason why it's doing that.
hi , i know a friend have one like that, same probleme he have to bring back to make it fix by the compagny,, only help can give you Yvon chow !!!
SOURCE: HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset
14 January 2008
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
SOURCE: Keypad Locked on Samsung SGH-E250
my upper key pad not functioning except call and power keys what should i do? and some times hanging on white screen. pls tel me the solution
