The floor tool seems to have a faulty clip - keeps dropping off the extension wand. Can the clip be replaced or will I have to purchase another floor tool attachment pls?
SOURCE: Floor tool wheel will not revolve on dyson dc08 origin vacuum
The wheels on the floor tool get junked up with hair pretty quickly, at least they did for our Dyson. The metal peg that holds them in has grooved teeth to prevent it coming out easily, but it will come out if you get a claw hammer and give it a good yank. I've just done this for ours, and it was clogged up bad.
This claw hammer pic is indicative only, to actually get it off, I had a foot on the main assembly, and both hands on the handle of the hammer, the peg is stuck quite strongly.
When you get the wheel out, it will probably look like this. (this is actually a bit cleaner than it may be, as I'd already removed as much hair as humanly possible with a knife before disassembly) Once you have the wheel out, remove the peg (can just tap it out with a hammer, you may need a punch to get it all the way out. Not having a punch, I used the handle of a drill chuck, but a screwdriver would also work :) )
Give it a wipe clean, the wheel should then rotate freely on the peg. Then put the wheel back on, and drive the peg in. I've left about a millimetre of play in the wheel so as not to have it stick to the side, and hence not work again. Also, test it in both carpet and wood floor mode before putting away tools, I remember changing modes and finding that all of a sudden the wheels were sticking out an extra few millimetres.
Hope that helps
Oh, and never mind the first picture showing the entire head assembly removed, it doesn't have to be. I actually removed it all before realizing that the wheels would just come off with a hammer.
Testimonial: "That was very helpful rollersmb. Your pics and instructions was worth a weight in gold.It is now fixed and my wife is very happy. Thanks. "
SOURCE: HI,
this is common you may have a short in the contacts from the handle to the wand or a break in the cord that goes into the powerhead
SOURCE: My Dyson 14 Animal seems to not have the suction
Hi its Darran at Dyson.
Firstly check that the brush bar control on the cleaner head is in the correct position. You may have switched the brush bar off the last time you used it or the dial may hav got knocked when you vacuumed under some low furniture.
If this is in the correct position but the brush bar is still not turning, switch the machine off and remove the soleplate by turning the 3 fasteners on the base of the machine and checking for blockages and remove any threads or hairs around the brush bar.
I would recommend washing the filter if it hasnt been done for a while.
You may find it useful to follow the blockage procedure and filter washing instructions in your user guide, however if you no longer have this available you download a replacement for free via the support section on our website at www.dyson.com.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
SOURCE: When I push the release on my Dyson, the vacuum
Sorry to hear you're having difficulties with your DC25. Due to the nature of your issue, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
