Flame comes on for 4 seconds shuts off for 5 minutes and flame comes on again4 sec repeat
SOURCE: Flame comes on for 15 seconds then shuts off. 1
you can try to clean the flame sensor window it works by light soot gets on the glass and blocks the light
SOURCE: maytag gas dryer-- My flame fires up ok but then
It is supposed to cycle on and off so it does not get too hot and burn anything.
SOURCE: dryer starts hot surface ignitor comes on gas
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
SOURCE: The igniter comes on, lights
There's a heat sensor that's in the path of the flame. It's supposed to detect when the flame is lit properly so you don't fill your house with unburned gas.
I'd bet that sensor has gone south, or maybe the wire going to it.
What brand/model is it? A diagram and parts listing might come in handy.
SOURCE: flame turns off rematurely
That is normal. The gas does not stay on constantly. That would burn the clothes. The gas assembly is controlled by a Klixon mounted on the blower housing. As the air comes through the blower The Klixon also known as the cycling thermostat judges air temp and turns the gas assembly on and off. Here is a video explanation:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
