Need to wire a silver salute cb mic to a cobra 142 gtl what color wire goes to what pin on the mic plug thank
Dont go by colors.. go by what wires are on the switch and mic element.. mics can be rewired and no one told you the colors could have changed FYI..
Pin #1 ~ Audio
Pin #2 ~ Shield
Pin #3 ~ Receive
Pin #4 ~ Switch Wire
Pin #5 ~ Transmit
always go by connections not color of the wire. that way you learn and you can do any mic. to any radio.
SOURCE: Diesel #8-32 echo power mics
cobra 4 pin is pin1= shield, pin2= mic audio (usually the shield is wrapped around the mic audio wire).pin 3= transmit or push to talk usually red or white whichever isnt wrapped with the shield, and pin4 = receive or speaker complete
5 pin cobra=1-Audio 2- Shield 3-Receive 4-Switching Wire 5-Transmit, you can jump pins 4 and two
SOURCE: Wiring Johnson Microphone to cobra 29 CB Radio
Use trial and error systemathically. If still refuses to work, mike and radio aren't compatibles.
SOURCE: CB Radio - Cobra 29 WX ST - Need Chasis wiring
This one you will need a digram. any wiring you need is on that page. Good luck. www.cbtricks.com/radios/cobra/29ltd_29ltd_st_29wx_st/graphics/cobra_29ltdwx-st_29ltd_sch.pdf
SOURCE: I have a 1990 cobra 148 GTL with 5 pin
The wiring is not likely to be the same.
The information on the radio is here:
http://www.cbtricks.com/radios/cobra/148gtl/index.htm
You will likely need to open up the mic to identify what your wires connect to to determine the correct oreintation. it is possible too you may find one of the models listed was used by Barjan and is nothing more than a rebranded microphone.
SOURCE: how to make a adapter for a 4 pin CB mic to a 5 pin CB Cobra 148 Gtl
they are factory made adapters on the market , look on www.copper.com or www.hyelectronics the should be listed on thier sites and the adapters are pretty cheap priced
It is 1White 2 shield three black 4 blue 5 red
does anyone know the wiring code for this mic for a crt 6900n much appreciated
