Door sensor alarm continually sounding since turned ff on...light is on when first open fridge but I put recorder in fridge and light stayed on when shut!, after a few minutes light goes off and then won't come back on when door opened..
SOURCE: Whirlpool Frost Free 460 door open alarm
http://www.repairclinic.com check how to repace it with the schematic diagrams you'll see how
SOURCE: freezer door pops open.
door adjustment may be needed and or a new seal is what i would recommend
SOURCE: freezer door won't stay shut
I have the exact same problem - very annoying. The only thing I found to work was to purchase one of those child safety locks. I bought the Kidco Appliance Fridge Lock S330 because it was the only one I could find that automatically relocks after you shut the door. Buy two (or more) at a time because the arm will eventually wear out and break (after several months depending on how often you use it). You can check out the product's details on eBay - that's where I purchased mine. Hope that helps.
SOURCE: kitchen aid open door sensor alarm keeps going off door is closed
Open door and turn power off then on twice. Then press the Overtemp reset.
SOURCE: doors not closing all the way
check level from back to front on fridge if good than check the amount of food that is stored on the door if u have a lot of bulk, weighty stuff they may be acting as a counter balance on the door when u close the left side the air that is trapped usually disperses into the unit and is not forceful enough to push open the door but if their is a lot of additional weight on door it makes the door easier to open and swing on hinge
