All the sudden all my pics are almost completely white. If you look close you can see my pic, but there are white lines going horizontally through them and makes it look really foggy. What is wrong and can it easily and cheaply be fixed?
SOURCE: hi i have a kodak
Are the lines from the camera or the printer?
I have a similar model and the only problems I ever had were printer related.
SOURCE: Lcd screen is black a the evf is black too. When
the ccd has went bad must be replaced . it will not focus with a bad ccd .
SOURCE: m753 camera when taking pics and reviewing them
Hi!
It's a loose connection between the CCD and motherboard - a very common problem with these cameras. Unless you have experience in camera repairs, you should give it to a local repair shop - don't let them say you it's a motherboard problem or something like that, it's 99% just a loose connection. I have repaired hundreds of these. I work in a Kodak service center.
Tom
SOURCE: When taking pics they end up pinky/purple with horizontal lines
Hi!
service center.
Tom
SOURCE: when I take pics w/ my kodak easy share c813. The
Sounds like it doesn't recognise the card.
Probably the first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
