Televison & Video Logo
Posted on Oct 11, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mitsubishi CS 40503 TV
Tv screen is a small stretched vertical line, almost like watching a dvd on widescreen option. sometimes the entire screen is normal size,but then randomly it will shrink. help ?
Vista Electronics
Level 3:
Genius:
  • Master 1,694 Answers
  • Posted on Oct 29, 2007
Vista Electronics
Master
Level 3:
Genius:
Answers
1694
Questions
Helped
585224
Points
2786
Bad connection vertical output IC.........T.
Anonymous
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Expert 556 Answers
  • Posted on Oct 12, 2007
Anonymous
Expert
Level 2:
Prodigy:
Answers
556
Questions
0
Helped
173161
Points
916
  • sometimes the entire screen is normal size
  • from this statement it is clear that there is a loose contact in tv
  • please check for loose contact in some components
  • loose contact in connector
  • loose contact in print.
  • if you are not tech person then take help from him.
  • hope this will help.
  • good luck.
Actually the model is cs-313050. its quite old. the problem is that the tv won't work in the way that when you turn it on (it won't even turn on anymore) there is nothing but a white or blue lineright in...
you didn't mentioned if it is a horizontal line but i think it is.
It seems that you have a faulty vertical I.C. that scan vertical line.Because you it is defective you've lost the vertical scanning thats why you have only a horizontal line on the screen.
You will confirm it by powering on the unit with your cable signal present.When the sound is present on every channel it is confirm that you have a problem on the vertical section. You must look for a qualified technician to solve the problem....
Mitsubishi CS-40503 TV previously had discoloration in the corners and lines at the top of the screen. Now I have no picture at all. Is it worth trying to fix?
no picture?do you see a white horizontal line in the mid?or black out?
its up to you if its really worth fixing. if its really old then ,i think its time to buy a new one, if not try comparing the cost.
Narrow blue horizontal line across screen on intial power up
You have trouble with the vertical deflection circuitry. Probably something in the driver circuit or power supply to the driver. Maybe even a cold solder joint since it comes up after a little warmup.
Mitsubishi CS-40503 shuts off while watching.
Could be any number of things, none of them easy to diagnose. Unless your a TV repairman it's probably not worth fixing. It will cost tou more in repairs than a new TV.
Mitsubishi CS-40503 Horizontal Picture Problems
Your trouble is with the vertical deflection circuitry. You'll need to have it serviced by a professional.
1helpful
2answers
FORGOT PASSCODE ON TV PARENTAL LOCKOUT
that's a big problem. sometimes using the 0000 can unlock it but it's not 100 percent.try the trial and error.
1helpful
2answers
1995 Mitsubishi 40" Television - Worth Repairing?
there are bad solder connections on the vertical deflection IC resolder them and you will be fine
Entirely black screen Mitsubishi Model CS40503 SER. 530082
  1. YOU WILL NEED TO CHANGE
  2. Q6c2
  3. Q291
  4. D251
  5. CHECK MOUNTING OF PIP-PCB TO MAIN-PCB
2answers
Mitusbishi tube
ok! you have defective vertical boost up! your defective parts is small capacitors or resistors! at vertical section!
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
