I cant find anywhere what the F35 codes means to solve the problem with my washer. What I do know is when it does run and doesnt give me the error code it leaks and I cant find from where. Help me please. Had our unit 3 monthes and the same issue is happening. SUD appears then followed by F35. Technician has been out and ordered a pressure switch part. That was 3 weeks ago! I called SEARS directly and they are shipping the part directly to my house. This part just plugs in and can be replaced by anyone themselves. hope this works.
We have a kenmore HE2 Plus washer, front loader. been getting F28 code for last several months. usually we can push cancel button, and it clears, unlocks the door, we restart and complete the wash. But now it is locked and we can;t clear it. have even unplugged the machine over night, it still will not reset. any ideas?
F35 that you cannot get past is the water level sensor, I've replaced several. It is on the right rear top, has a small black hose running to it, and a sm wire harness connector. This is a new style sensor, electronic, size of your thumb, brown, and a piece of junk. The old style worked much better.
Hello & Welcome to FixYa
F35 error means that there is some sort of issue
with the steamer electronic board and analog pressure sensor has gone bad.
Check that the hose is firmly attached with the washer and is not blocked. You
can also check the water level pressure switch operation. Please get back to me
if you have any other questions.
Kevin
Place the unit into the back of your pickup, drive to the nearest bridge, and toss it over the side. I will never purchase another Sears brand appliance. It has been 7 weeks now and still no working washer.
