SOURCE: refrigerator freezes fresh food section and always runs
Please read it appears that there are two defrost timers for your refrigerator one for the freezer one for the refrigerator
http://www.partselect.com/PartDetail.aspx?Inventory=310858&SourceCode=4#RepairStory
SOURCE: ge fridge GSS25LFGww, fridge part freezing food
Hi, Change the controls back to normal settings. Make sure the freezer is getting 0 to 5 above. If the freezer is getting cold enough, try and turn the cold control to 1 and see if the refrigerator shuts off. It sounds like the cold control in not working properly and will need to be replaced. NOTE: The freezer temp has to be right temp or the fresh food side will not work proper.
I hope this helps. Please let me know if I can assist you further.
Vic
SOURCE: refrigerator side freezes even on lowest setting?
It may be a problem with the damper panels that are situated between the freezer and the refrigerator. Most people note a problem when the damper doors stop opening and food becomes warm. In your case the doors may be not closing properly.
This may be mechanical, the damper louvers assembly is broken, or it may be electrical, the relay switch and motor assembly that operates the damper is not operating properly.
In side by sides the damper is usually in the upper side rear of the refigerator. If you can peer into it, you may be able to see light from the freezer (freezer door open) which would confirm the louvers are open.
Quick fix? duct tape a portion of the opening. It will restrict cold air flow. Costs little, and if you are not particular will work. Other fix. Call a repair man and be prepared to pay about 200 for the parts and labor.
Aloha
SOURCE: food in refrigerator is freezing
check the damper door between the freezer and refrigerator compartments,it most likely has frozen in the fully open position allowing cold air into refrige compartment all the time,you will see ice build up around the damper door unit,remove the door unit defrost,replace and then see if it moves when you change the refrige cold control
Testimonial: "Worked great thank you"
SOURCE: My G.E Adora refrigerator freezer
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
There can be many reasons why your
refrigerator is freezing your food. To see what could be happening
and to figure out how to possibly fix your problem. Take a look at
this tip which contains many of the causes and solutions to fix the
problems.
Refrigerator
is Too Cold and Freezing Food
heatman101
