GE Model 25951EE3-A
SOURCE: change language on answering machine
press and hold the skip button for 2 seconds and it will go back to english
SOURCE: How do you set the number of rings before the answering machine picks up?
Here's a link to the manual on AT&T's site:
http://telephones.att.com/telephones_ui/support/dsp_manual.cfm?manualID=284
SOURCE: GE answering machine Model #
There is a RING SELECT switch on the rear of the base which allows you to select 3 or 5 rings. You can find the user's guide here for more information.
SOURCE: phone is plugged in to
Change the answer machine rings to answer number to less than the fax number of rings to answer or increase the number of rings to answer on the fax machine. Would need exact model number of phone system to give more detail on programming steps. Info should be in manuals of phone system and fax machine.
