Saws Logo
A
Anonymous Posted on Nov 28, 2013
How do you use a somax 250 - Saws
Kenneth Walker
Level 2:
Sergeant:
  • Expert 293 Answers
  • Posted on Apr 19, 2019
Kenneth Walker
Expert
Level 2:
Sergeant:
Answers
293
Questions
0
Helped
93187
Points
736
Please help. Need replacement carb for a QLINK legend 250...
250CC Automatic Motorcycle Carburetor CFMOTO V3 V5 ...
eBay https://www.ebay.ca > itm
250CC Automatic Motorcycle Carburetor CFMOTO V3 V5 Qlink Legacy Sapero 250 ... Decent replacement, with an OK fit, for the original Mule 550 master cylinder.
$133.15 · ‎ In stock
CFMOTO Qlink 250 Automatic Motorcycle Scooter ... - eBay
CFMOTO Qlink 250 Automatic Motorcycle Scooter Carburetor V3 V5 Legacy Sapero Com ; Quantity. 12 sold. More than 10 available ; Item Number. 183200768184.
$146.66 · ‎ In stock
CFMOTO Qlink Carburetor for V3 V5 Legacy 250 Sapero
Whygostock.com https://www.whygostock.com > cfmoto-qlink-250-aut...
Sep 5, 2019 - CFMOTO Qlink 250 Automatic Motorcycle Scooter Carburetor V3 V5 Legacy Sapero Commuter Fashion Baron. MSRP: Now: $119.99.
Rating: 4 · ‎ 1 review · ‎ US$119.99 · ‎ In stock
1helpful
Need replacement part for MS 250 C ignition coil
There was two ignition coils used on the MS250C series. Which do you have?
MS 250 C-B, MS 250 C-B Z, MS 250 C-BE, MS 250 C-BE Z ?
Also these parts are only available through Stihl dealers.
Antilog of 250
The common antilog of 250 is 10^250 (a one followed by 250 zeroes).
The natural antilog of 250 is about 3.75*10^108.
I need to know if there is a program that can decode ANSI code to readable english Here is a sample of the code úÿÿÿC   x x ...
yes here is the link its from Microsoft http://www.microsoft.com/downloads/en/details.aspx?familyid=048DC840-14E1-467D-8DCA-19D2A8FD7485&displaylang=en         hope this helps and please vote
2helpful
2000 Hornet 250: what is the ideal tyre pressure in hornet 250...
NEVER the same pressure on both tyres !!
Usually, rear tyre is larger and/or carries more weight (you), therefore needs a much higher PSI. On a Hornet 250, 600 or 900cc it should be 36psi FRONT and 42psi REAR. - check the manuals.
Need a 1972 Honda XL 250 that needs a kick starter Shaft
you will have to find the same model, there were no xr back then
Percent to chemistry problems.
Hello
You should ask a question, we cannot guess what you want.
Percent means per 100 or 1/100. So 75% = 75/100 or 0.75. Here are some exemples of percent calculations with %
Percentage (5% of 250)
250 [x] 5 [2nd] % [=] gives 12.5
Ratio (Ratio of 250 to 5)
250 [/] 5 [2nd] [%] [=] gives 5000.
Add-On (5% add-on of 250)
250 [+] 5 [2nd] [%] [=] gives 262.5
Discount (5% discount of 250)
250 [-] 5 [2nd][%] [=] gives 237.5
Some percentages and decimal equivalents
1 = 100% ; 2 = 200%, 3=300%
0.5 = 50%
0.4 =40%
0.1 = 10%
1/3= 0.33333 = 33.33%
1/4 = 0.25 = 25%
2/3= 0.66666 = 66.66%
1/5 =0.2 = 20%
1/8 = 0.125 =12,5 %
Hope it helps.
1helpful
I have an older 250 xt 1980's but cannot find out what year as the serial is not 17 digits (3Y2 000175)
Hi
Did some extensive searching for you. You may need to call an old school Yamaha mechanic to pull that one up for you. Tpo give you an idea of what was being produced back then, found this list ...
XT 250 G 80-81 3Y3,5g4
XT 250 G 80 3Y4
XT 250 H 81 3Y1
XT 250 J 82 15Y
XT 250 J 82 3Y1
XT 250 J 82 3Y4
XT 250 K 83 3Y1
3y2 does not appear anywhere. But the series of number indicated for the XT250 above point it to probably being an XT built between 1980, and 1983. Best I could find. Hope it helps
regards robotek
Top Saws Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Saw Expert? Answer questions, earn points and help others
