Thermador PSC364GDZS Gas Cooktop Logo
Posted on May 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I left cillit bang on the stainless steel hob too long and it has horrible stains on it
Bruce
Level 2:
Scholar:
  • Expert 145 Answers
  • Posted on Jul 27, 2009
Bruce
Expert
Level 2:
Scholar:
Answers
145
Questions
Helped
70551
Points
172
Use appropriate solvents to remove the plastic. If you are skilled sanding in straight lines and matching the grain in your metal use 180 grit - 240 grit blending and using your eye. You could also use scotch brite #7447 purchase at an automotive store. This pad after solvent or used with it could remove the plastic or both sand and pad.
Debruce Polish is the best our there at maintaining a pristine finish and it is eco-friendly and odorless, we use this in all our properties AND the ceramic cook tops it is safe for glass. It also removes rust... we just love it. We find DeBruce polish at debrucepolish.com.
Lamona 1851 Induction Hob - squeaking noise
It may be the alarm that is telling you that the cook pan is not making a good connection to the hob. Does it do it with all pots? Stainless steel, copper sandwich with ground bottoms are best. Mine are Lagostina. At work, we had a Wok Station and when we used a standard pan, it would beep it you turned it up too high. Not problem with a stainless steel wok.
Howden's Joinery are not the maker, but the exclusive distributer. Contact them and ask.
https://www.howdens.com/contact-us
Jan 20, 2022 • Cooktops
2answers
HOW DO I UNLOCK MY SCHOTT CERAN CERAMIC HOB
l means locked hold two left buttons at same time or the two right buttons or the bottom two buttons or top two buttons should solve your problem you have to do it prety quick or the computer thinks a child is trying to turn on the appliance
Horribe stains left on whirlpool gas hob by domestic cleaner
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
This stuff will do the job!!
1helpful
2answers
The stainless steel rings on my cooktop are already getting burn stains. How do I clean them without discoloring the rings?
2helpful
2answers
Cillit bang damage to stainless steel hob
I left cillit bang on my Whirlpool stainless steel hob. It left a real mess and looked ruined, however I have a solution. You need Astonish cream cleaner, I got mine from the Kleeneasy catalogue, just get a damp cloth and rub gently all over. You might need to do it a few times, wipe it clean with kitchen roll then rub some oil (I used olive but baby oil is good) and it should buff up to a really good finish.
Mar 19, 2009 • Cooktops
Gas cooktop surface
Stainless is hard to clean if you dont keep up with it. Black is horrible because you see every imperfection. white turns color after some time..
I suggest stainless if you keep up with it.
Stainless steel hob
the scratch you "may" be able to work out with some careful scouring, with hte grain ofhte metal. the dent however is not going to be remeidied in any way other than replacement
39helpful
2answers
Cleaning Thermador Cooktop?
To clean the stainless around the star burners try applying Easy-Off oven cleaner around the stars with a Q-tip (spray the cleaner onto the stainless surface first because it's very hard to control the spray output). The cleaner will make your stainless sparkle and the Q-tips allow you to get close enough while controlling the application. Scrub gently with the Q-tip and the stains will disappear within minutes. Wash thoroughly with a wet cloth. I've used this on my older model Thermador stainless cooktop for 5 years.
Stains from cleaning products?
Bosch (BSH appliance care) do a stainless steel conditioner you could try. I think its called Starglanz.
Top Thermador Cooktops Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
